Old 06-08-2024, 02:07 PM
form74's Avatar
form74 form74 is offline
Default Trans line placement
Do the trans lines lay between the motor mount and the fuel lines or do they lay between the motor mount and the oil pan I forgot to take a picture when I took the old ones out had the motor in already and couldn’t get them in so now I yank the motor again
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
Old 06-12-2024, 03:52 AM
Formula403 Formula403 is offline
The trans lines are on the RH side, run up just below the upper control arm. Fuel line on other side. Or are you talking about something else?
