Special Paint Code
Hello, my '67 GTO project car has a 1 paint code on the body tag. I realize that simply means it was a special order color. Searching around the interwebs, it seems the most common special order in '67 was tiger gold. I did see another car that was special ordered a hideous orange color, also labeled 1 for paint code. I also found a blurb that verdoro green may have been available as special order in '67. Is there any one who knows what all of the color options were for special order, or is it unlimited? I can't seem to figure out what my car was originally painted, although white seems to be the most recent color. Would a special order paint code car be worth more? Thanks for the information!
To find the original color of your car you might want to look under some of the molding on the car. Even if repainted it may still be under the moldings as in older paints they didn't always paint under all the moldings & weather strips as it was to much work to remove all of them for paint. Also you may want to look in the trunk area for parts that wouldn't have gotten painted because it was to hard to get to. I'm sure you'll be able to find the original color of your car if you look under all the parts of the car that are hidden.
IIRC the 1967 "Special" colors used a 1,2,3,4, number code.
1= Non "Pontiac" GM Color. 2= Non GM color. Sometimes stamped on tag as SPEC. 3= ? 4= Primer. Sometimes stamped on tag as PRIMER.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
To expand a bit on my answer.
I looked through my chip charts and did not see a definitive color chart/list for "Special" colors. However I did come across this note on the 1st Gen site for '67. Custom Factory Paint is indicated by (“2”, “1”, “4”, “PRIMER”, blank, ‘—-‘, ‘SPEC’, or ‘special.’ ) The special order Pontiac Colors were; Verdoro Green (usually used “Q”), Mayfair Maize (usually used “Y”), Coronado Gold (sales code 867-97904), Copper Blaze (867-98105), Sierra Red (867-97592), Silver Turquoise (867-99079), Blue Charcoal (867-97211). The data plate for the Paint Code may have been marked “2” for Pontiac special order colors, “1” (or Blank) for non-Pontiac colors, and “4” (or “PRIMER) for primer-only finish.) IMO it could be something that is an almost unlimited list of colors if one was willing to pay for it.
Thanks for all the information! I'll have to see if I can find a sales code number. What I think is really cool is the amount of customization a person could do when ordering a car back then. You really were able to make a car your own. If 15 color options along with vinyl roof options and different color interiors weren't enough, they would allow special orders like this. Things have really changed!
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
Mine is a special order color car....
Data plate is blank where paint code should be Car was ordered Buick Riviera Charcoal Gray
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
I met the original owner of a 67 GTO. His father-in-law owned a Pontiac Dealership and ordered him a Verdoro Green GTO. It sounds awful but it actually looked great.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed 69 GTO, Verdoro Green, Green, 400, 4-speed 69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet |
from a dealer brochure- Special Paint 67 colors
It is my understanding that the colors were not limited to the color chips I'm posting, but that any 1967 GM color, just not a Pontiac Color. I've seen some interesting examples of 1967 color choices including Sunfire Yellow 67 GTO in Florida and my 1967 Marlboro Maroon car. If I'm not mistaken there is a 1967 Honduras Maroon Ram Air car in New York, although Honduras Maroon was not a 67 color choice. I'd love to see data plates posted for 67 Special Paint cars.
Yes that is the sheet I have and posted info; from above.
As you can see these WERE colors/names used on Pontiac & Tempest. Back in the day one could pick any GM color at an *Extra Cost. There have been some reports of None GM colors ordered as well. The one that comes to mind is a Known PINK '67 GTO that was ordered that way.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 10-22-2017 at 12:00 PM. |
1967 Special Paint Cars
I would love to see pictures of Data plates for Special Paint cars if anyone is willing to share. I'll post my plate tonight.
Do you have a picture of the pink 67 GTO and it's plate? i wonder if that was a Mary Kay car or something that was ordered... it would be interesting to know the history and see examples... |
It wasn't connected to MK it was just something someone wanted.
IIRC it was featured in POCI's SS newsletter about 10/15 years back.
In my experience mostly with '64s, the coding for Special Color paint builds varied by Plant so don't expect to match a given color to a Data Plate Paint code.
Sometimes Fisher Body coded the Dupont formula code on the Data Plate. That makes it easy. You could order a near infinite no. of colors. As long as Dupont had a formula code for it, you could order it and Pontiac would get the paint. If you liked the color on your '58 Lincoln, you could specify it and order a '67 Bonneville to be factory painted the same color. The paint would be formulated as a modern acrylic lacquer if it wasn't that type to start with but there was no limitation in the colors you could choose. A surprising no. of cars were ordered with special colors. I say surprising since the upcharge was not insignificant back when the base price was less than $4000. And also the fact that it wasn't gonna make the paint last any longer (or the car for that matter). And it also delayed the build because the paint had to be ordered and delivered to the Plant (2 quantities, one for Fisher Body and one for Final Assembly where the front end sheetmetal was painted) before they could schedule the build. Even more common were the extra cost "regular" special colors that Pontiac sometimes offered, often as "Spring" colors to spice up a model year that was beginning to grow "old and boring". Special Color paint cars are interesting. Debatable whether they add value. I believe it was standard practice to ship each Special Color paint car with a quart of paint for potential refinishing. I agree that it would be worth looking in hidden areas for evidence of the original color. My '64 convertible is not a special color car but had a color change some years before I bought it. The original color was quite easily found on the sides of the cowl when the fenders came off, under the sills, under the window moldings, and numerous other nooks and crannies that were hidden from view when the color change paint was sprayed. When you expose those areas, it may be difficult to determine exactly what color it was although perhaps it will be one from the '67 Special Order Exterior Color chart and will be obvious. |
Excellent post and valuable information, John. Thanks for the in-depth break down of how all of this came to be.
There are some color photos of a Verdoro '67 in one of the big GTO coffee-table books. Can't remember which one now. It IS a great looking color on that car.
Greg Reid Palmetto, Georgia |
Greg, at least 3 pix of it are in Tom DeMauro's GTO "The Restorer's Guide 1964-1974".
I remember being surprised when I saw it in there since I only knew Verdoro Green as the iconic '68 GTO color. I also thought it looked great on that '67. |
Thanks John. Couldn't remember where I saw it.
Is there any records as to how many special order colors were made ?
My car is a Freemont made '66 GTO code paint " 1" that I know for sure was Tiger Gold. I know it's not super rare but I wish I knew how many were produced. |
I do not believe there is any breakdown for colors...... I also would be interested since mine is also a Special Order color...
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
