Old 10-28-2023, 03:45 PM
hoondogg hoondogg is offline
Default Tach inop 78 Formula
1978 Formula. Tach is not working. On the coil, there is batt and tach. Should there be 12volts on both terminals when the key is on and engine is off? I have power on both tach wires at the tach when engine is off and key is on.
Old 10-28-2023, 07:29 PM
Trevor78 Trevor78 is offline
Standard, the engine isn't running so gauge shows that even with power there. A 78 tacho should hang down when off and not return to 0, except when powered up. If needle doesn't twitch, then there's nothing going on there. The tachos also commonly failed 45 years on, expensive and flimsy to repair only to fail again. At least there's a reproduction now available, at least for some years.
Old 11-09-2023, 11:42 AM
DanC's Avatar
DanC DanC is offline
Arrow New Tach Circuit Board ...
Not mine! I've seen this on eBay https://www.ebay.com/itm/142558219997
DanC
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 11-09-2023, 03:50 PM
The years are wrong. 79-81 quartz clock type.
Old 11-10-2023, 10:53 AM
bhill86's Avatar
bhill86 bhill86 is offline
Thought there were late 78 versions that didn’t say quarts above the clock and yet had the new tach and clock mechanism inside.
1977 Trans Am 400/4speed (swap)
Brian
Old 11-10-2023, 11:12 AM
Not sure exactly when the changeover was, if 1st 79 model or gradual late 78 model etc. Point is you need to know what tacho you have and that this type only fits the Quartz clock version. Different tach internals and operation, different clock, different gauge rear shape. This version not done repro so the circuit board can be a handy part to have. The early models didn't say Quartz even though just swapped to it, but could be identified anyway as the tacho needle returned to 0 when off, not hang down.
Old 11-10-2023, 12:31 PM
bhill86's Avatar
Agreed
Brian
Old 11-10-2023, 10:43 PM
For sake of adding detail pics... thanks Tom, saved me uploading.
Non-Quartz clock and tacho version....round rear body and small round circuit board.
http://www.thepartguy.com/images/pro...Qtz)tach-4.JPG
http://www.thepartguy.com/images/pro...Qtz)tach-3.JPG
Quartz clock and tacho version, even without Quartz text on face.... plastic rear body with flat sides, large half moon circuit board almost same size as gauge body.
http://www.thepartguy.com/images/pro...-81)Tach-3.JPG
http://www.thepartguy.com/images/pro...-81)Tach-4.JPG
