Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-04-2024, 01:56 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default F/S Ram Air Factory Manifolds and Pipes
Chicagoland area - 60047 will be the shipping zip code.
I ran these on my ‘65 GTO flawlessly.
Original Pontiac castings.
9797072 RH (1968 and later casting).
9777646 LH (1964-67 casting).
2.25 outlet sizes.
Both use the 3-bolt outlet style flanges.
LH manifold had a cracked outlet lip, which has since been ground flush and replaced with a FEL-PRO exhaust donut gasket (#60718) that works perfectly. Crushes almost to the size of the original lip (.250).
Castings were recently sandblasted and painted with VHT high temperature ‘Dull Aluminum’ spray paint (#SP117), and used on my engine run-stand.
Attachment bolts (factory type) included (manifolds to heads), sourced at Ames.
A new FEL-PRO exhaust donut gasket is included.
$300.00 for the manifolds.
Buyer to pay freight. Money Order or personal check only.
Full pipes with Flowtech dumps match the available manifolds and are for sale as a separate item or can be purchased with the above manifolds. Used on my engine run-stand and recently powder coated semi-gloss black using Columbia Coatings powder that is rated to 1,500 degrees. Pipes have the 3-bolt style flanges. Attachment bolts included (pipe flanges to manifold outlets), sourced at Ames. Pipes were used on my ‘65 GTO, may crossover to later A body vehicles. Not 100% sure.
$300.00 for the pipes.
ID:	629797   Click image for larger version
ID:	629798   Click image for larger version
ID:	629799   Click image for larger version
Old 03-04-2024, 02:00 PM
More pics.
ID:	629801   Click image for larger version
ID:	629802   Click image for larger version
ID:	629803   Click image for larger version
Old 03-04-2024, 02:08 PM
More pics.
ID:	629811   Click image for larger version
ID:	629812   Click image for larger version
Old 03-04-2024, 08:39 PM
Pipes are 2.25 diameter.
Old 03-10-2024, 07:44 PM
Sunday 3/9 Bump.
Old 03-17-2024, 09:55 AM
Sunday 3/17 Bump.
Old 03-24-2024, 10:30 AM
Sunday 3/24 Bump.
Old 03-31-2024, 06:21 PM
Sunday 3/31 Bump.
Old 04-07-2024, 05:34 PM
Sunday 4/7 Bump.
