Old 03-23-2016, 08:23 PM
mike76 mike76 is offline
Default is one rear main cap better than the other?
Here is a pic of 2 rear main caps. Don't know if one is better than the other. I think the top one takes the rubber seal while the bottom one takes the cork gasket. Thoughts?
Name:	rear main caps.jpg
Old 03-23-2016, 08:30 PM
Tom Vaught's Avatar
Boost Engineer
Is one of the two caps for the block you want to use in your build?
If so, use that one. Same deal for the front cap.
Tom V.
Old 03-23-2016, 10:33 PM
Big Injun's Avatar
Big Injun Big Injun is offline
To further what Tom is driving towards, is if you use a main cap from another block, you will need to have a line bore done to make certain the mains are all lined up.
Dave "Big Injun" Anderson
dave@4mypontiac.com
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 03-23-2016, 10:49 PM
Need to have mains aligned bored/honed anyway. Just wondered if one cap is better than the other. Thx
Old 03-24-2016, 03:48 AM
Kenth's Avatar
Kenth Kenth is offline
I would use the one that goes with the block.
If you chose the rubber seal style also use the 5-prong pan/seal.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
