Old 01-23-2021, 01:39 PM
MUSLCAH MUSLCAH is offline
Default Fixing that gap..
[ATTACH]Click image for larger version
Had a good gap...until the end near the Windsheild....Fiddled and tapped ...but not getting anywhere. So go out the air saw ...and made a slit....then removed a little more metal from the slit....then with a screwdriver ,make the gap I wanted and welded up the seam. Like new now.
The Following User Says Thank You to MUSLCAH For This Useful Post:
Old 01-23-2021, 01:47 PM
Some grinding and a wee bit more welding ....and a nice gap now. Hope this helps
Old 01-23-2021, 01:49 PM
The pics don’t really show how far off that gap was.....but you get the picture
Old 01-23-2021, 08:53 PM
tjs72lemans tjs72lemans is offline
Yes. Looks good and should work well . I wish I could've done the same on my passenger side. Unfortunately, I bought the car apart and mostly painted. I put together and did all I could adjusting door, core support and fender and still closer than I'd like at that top point. If nothing ever moves, I won't chip paint.
Old 01-24-2021, 09:57 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
That worked out nice.
Old 01-26-2021, 03:41 AM
Mine could use a little 'closing up' in that same area...but way past that point now.
Old 01-26-2021, 11:13 AM
I get cars in my shop...that the guy wants his gaps to look like Bitchin Rides gaps.....And tell captain obvious....that’s the first step you do....not the last. And those are AMD parts....they still need massaging
Old 01-26-2021, 02:11 PM
craigs69's Avatar
craigs69 craigs69 is offline
I had to do that with my front valance panel. It didn't fit correctly where is meets the fenders and the lower grille openings were 1/4" larger than the chrome trim.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
Old 01-28-2021, 03:04 AM
What car is that MUSLCAH? Looks like a '68-'70 A body. The gap I'm referring to on mine is in the exact same area. It never showed until a couple months ago when I finally got around to addressing some hood fitment issues. It eventually became obvious that I needed to go back to the doors and work forward to get everything lined up.
That passenger fender had to come forward a bit as part of that and when all was said and done, that gap is a little wider than it used to be...but the hood issues are much improved along with the door and quarter glass so I'll take the tradeoff.
Old 01-28-2021, 11:53 PM
A customers 67 Camaro....that hit a deer.
