Old 01-16-2021, 09:18 AM
79TA455's Avatar
79TA455 79TA455 is offline
Default PCV Valve grommet
Does anyone know the best place to purchase the replacement rubber grommet on the PCV where it attached to the crankcase filter? Either that or the best way to create your own? This is a '76 Trans Am 400 and rubber is old and worm out so I want to replace it.
Picture for reference.
Old 01-16-2021, 09:28 AM
thepontiacman's Avatar
Try Ames or inline tube
Sent from my Moto Z3 Play using Tapatalk
The Following User Says Thank You to thepontiacman For This Useful Post:
Old 01-16-2021, 09:56 AM
I've always used a short piece of heater hose for that.
What fits the pipe has to be stretched on the filter. Not too bad with fresh warm hose and a little lube.
Clay
The Following 2 Users Say Thank You to "QUICK-SILVER" For This Useful Post:
Old 01-17-2021, 11:32 AM
jd0n88 jd0n88 is offline
That's what I used. 3/4" ID heater hose.
The Following User Says Thank You to jd0n88 For This Useful Post:
Old 01-18-2021, 09:07 AM
79TA455's Avatar
Thanks for the info guys. I figured it was that easy. I'll have a look through my small stash of hoses and see what I have.
Old 01-18-2021, 11:03 AM
burd's Avatar
burd burd is offline
OG hose has ribs.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 01-18-2021, 11:08 AM
NeighborsComplaint's Avatar
Ever been to an auto parts store? In the Dorman "Help" section, they have every rubber grommet size imaginable. Autozone, O'Reilly's Advance all carry the same stuff.
Triple Black 1971 GTO
Old 01-20-2021, 03:28 AM
lust4speed's Avatar
Might hinder your search if looking for a PCV grommet since the line you have pictured is a vent tube. Looks like Ames doesn't carry it, and I'd just use a piece of heater hose as suggested above.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 01-20-2021, 06:18 AM
Held for Ransom's Avatar
Ames should carry it. PN N178F, $2.00
https://secure.amesperf.com/qilan/De...part_num=N178F
So long, farewell.
Old 01-20-2021, 11:13 AM
burd's Avatar
I’m got a nOS chunk, it wasn’t cheap, it has the correct ribs. Dont use heater hose. It ain’t 2 quid though for a pic, lol
It’s not called pvc grommet, that is in your valley.
F ire B irds
Old 01-20-2021, 02:26 PM
unruhjonny's Avatar
so is this actually about the circled part in the image (vent tube piece of hose connecting to the air cleaner filter), or is it about the actual Positive Crank Vent rubber in the valley pan?
I would like to source a couple of those, as well as a couple of the rubber valve cover pieces that the vent tube goes through, preferably some sort of search that doesn't require me buy parts from another country, several hundred miles away.
1970 Formula 400
Old 01-20-2021, 05:01 PM
Jonny, does your parts stores have a Dorman Help! section? See if they can order you a PN 42055 (valve cover vent tube grommet) or 42054 (PCV grommet).
So long, farewell.
Old 01-20-2021, 07:15 PM
unruhjonny's Avatar
Thank you very much for those numbers!!
ages ago I bought several valve cover ones, and all were the wrong one.
1970 Formula 400
Old 01-20-2021, 07:41 PM
I had to relook up the valve cover number as I had posted the wrong one at first. OE was 9776721. And the PCV grommet goes in the valley pan.
So long, farewell.
Old 02-09-2021, 05:43 PM
unruhjonny's Avatar
I figured I might as well update this;
I ordered a valley pan grommet (Dorman #42054), and what I thought was a couple valve cover grommet's (WVE 2P1003 {#1231486, 29105, PCG103}).
To my dismay, these valve cover grommet's are NOT the correct part. I'm guessing they are mis-listed Chevy small block valve cover grommet's. This is a real bummer - but not worth enough to bother with trying to return them.
I'm chalking this up as a little bit of bad luck.
1970 Formula 400
Old 02-09-2021, 09:25 PM
That's the Dorman 42061 piece. Couldn't they order the Dorman 42055 grommets?
So long, farewell.
Old 02-10-2021, 12:24 AM
unruhjonny's Avatar
I did a search for "1970 GTO; 6.6litre" and this was the one listed;
I did an entirely different search today and did find the dorman 42055;
I am considering this as just bum luck - I took a chance, and it didn't work out.
Hopefully my post prevents someone else from buying the wrong part.
1970 Formula 400
Old 02-10-2021, 06:13 AM
But that was why I changed my earlier post. I should of had the correct numbers listed (even OE) so you didn't have to GOOGLE anything.
So long, farewell.
