Old 01-23-2021, 07:08 PM
GoGoat GoGoat is offline
Default Temp Sender
Should a guy use Teflon tape on temp sender?
Old 01-23-2021, 07:17 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
You can, just don't use to much.
I prefer a liquid Teflon myself.
Old 01-23-2021, 07:41 PM
steve25 steve25 is offline
If your threading into Aluminum, I would for sure use tape so you don’t run the pipe thread of the sender in so deep to get a seal that it expands out the Aluminum. In other words you get the needed seal with less force.
Also in this type of situation I would for sure use tape, not liquid!
If your just going into cast iron with a brass sender and those threads are good and so are those on the in the cast iron then I would just put it right in like the factory does!
If there both cast iron then I would use the liquid Teflon to avoid rust issues.
Old 01-23-2021, 10:22 PM
lust4speed's Avatar
Most of our senders are single wire and rely on a ground path through the threads. A wrap of Teflon tape can nicely isolate the sender and cause problems. Liquid sealant would be a little better and I probably go overboard using anti-seize paste on my senders.
Mick Batson
Old 01-23-2021, 10:27 PM
Old Goat 67's Avatar
NO, never had a leak there in 53 years of ownership.
Needs a clean ground.
The Following User Says Thank You to Old Goat 67 For This Useful Post:
Old 01-24-2021, 02:55 AM
CatalinaMike CatalinaMike is offline
Anti-seize or nothing at all
Old 01-24-2021, 08:09 AM
95% of the time you will still get a good to go electrical ground with just one rap of Teflon tape yet still get a improved seal.
If your sender is brass like what I had with my 1/8” pipe thread electric fuel pressure sender I used tape for a better seal and then soldered a separate ground wire on with a lug on the other end which was grounded in my case at the carb mounting pad just to insure a 100% ground , and more importantly no ground spark’s near the fuel itself!
I myself do not like using antisieze anywhere external on a motor next to where it can be seen, as in next to a nice painted surface since it will always run out or off to some extent and look like crap!
Old 01-24-2021, 07:52 PM
geeteeohguy's Avatar
This^^^^. It's a pipe thread and doesn't need add-ons to seal properly. Also, it needs a clean ground as Charles states.
Jeff
