WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2004-06 GTO Owners > 04-06 Engine Tech
04-06 Engine Tech LS engine tech center. Get the most out of your car here.
Old 03-14-2011, 04:28 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Check your fuel line near the rocker cover
Was cruising the LS1GTO site and saw a thread for the first time about this. Looked at mine and sure enough the plastic cover had worn a little cut in the fuel line so ordered a Russel braided.
Skip Fix
Old 09-12-2013, 03:42 PM
brandont's Avatar
brandont brandont is offline
Pypes & PY Tech
I noticed it on our 05 GTO. I took a 3/4" hose, cut a 2" piece then sliced it down the side. Installed it over the fuel line with two zip ties. You never know its there and now you don't have to worry about an engine fire
Old 11-06-2013, 09:58 PM
Abe05GTO Abe05GTO is offline
I ordered the Russel kit after finding out that the stock line was being cut by the FRC. The kit was less than $70.00 and added a bit of street cred, bling and safety so I didn't mind the cash outlay.
Featured Vendors
Advertising Info
