Old 01-03-2020, 11:33 PM
formula kid formula kid is offline
Default 1974 gas tank
Looking to buy a new gas tank, would like to know who has done the same and which you used. I know In 75 the fill tube changed and that is the problem. The restriction for the unleaded nozzle.
Old 01-04-2020, 10:39 AM
77 Canamman's Avatar
you can purchase the 1974-78 tank without the neck, and have your neck soldered to the new tank.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-04-2020, 12:53 PM
Thanks for the reply. Was hoping to find a company that sells the correct tank and neck. or where to get a new neck. I know the restrictor is tack welded in does anyone give you the option of not having it added?
Old 01-04-2020, 01:44 PM
The 1974 cap is a lot different than the 1975-up cap, so the restrictor is not the only issue. The Spectra tanks are fine, if you get one that does not have shipping damage.
Old 01-04-2020, 06:42 PM
ladytata's Avatar
ladytata ladytata is offline
You could take the old neck off your tank,?
Old 01-07-2020, 10:55 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
The other difference is the tube for the tank vapor that goes to the canister. You will also have to transfer your tube (or make a new one if yours isn't good) to the new tank as well. I had to do this with the new tank for my '74.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Thread Tools
Display Modes
