Old 01-23-2020, 10:02 AM
79TA455's Avatar
79TA455 79TA455 is offline
Default Sun visor questions
My sun visors have a mind of their own depending on what the car is doing. The drivers side one will swing without any effort so if I accelerate hard and it is down in front, it will swing and hit me in the head . The Passenger ones comes down on its own.
So my question is, if I get new brackets, will this resolve both issues or does it have to do with the screw that holds the visors on? I believe the driver one can be resolved with a new bracket but unsure about the passenger one.
Old 01-23-2020, 10:45 AM
77 Canamman's Avatar
The tension screw keeps the visors from tilting down. The bracket keeps them from swinging back. The only ones worth a crap are the GM brackets.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-23-2020, 11:56 AM
79TA455's Avatar
I can get OER....are they any good?
Old 01-23-2020, 12:58 PM
Aus78Formula Aus78Formula is offline
Be aware that there's variations in the repro sunvisors and brackets, not all follow original style with screw, others have used a bush insert which is then different to mount. For a while you couldn't even get new visors that were factory style so the brackets were made to suit them, while also working on originals, and probably being perfect for neither as a compromise. I'm not sure what brand they were but I had a repro set of brackets test fit into the roof and the holes one way which left the visors angled down wards slightly. A similar set that appeared identical to look at was completely different mounted up and perfect. I don't recall the brands of either, but likely MCI or OER, 10 yrs ago. The stock grub screw actually works like a fender U-nut retainer, as you screw it in it squeezes the inside closer which has the shaft inside for the mounting bracket. The surface for the shaft can become worn smooth and undersize at commonly used angles, which is why loose at some more than others.
Old 01-23-2020, 01:10 PM
79TA455's Avatar
This whwre I am getting them from since they are Canadian and shipping it not unreasonable:
https://firebird.musclecarsandclassi...acket-20057366
https://firebird.musclecarsandclassi...oupe-1965-1973
Old 01-23-2020, 01:52 PM
Why 70-78?
Old 01-23-2020, 02:14 PM
79TA455's Avatar
Originally Posted by Aus78Formula View Post
Why 70-78?
No idea.
Old 01-23-2020, 07:16 PM
https://www.ebay.com/itm/NOS-1971-77...YAAOSwQ-BdWdSc
GM 9809499 OR 9689897
