Old 04-28-2020, 11:04 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Default 1974 Exhaust Tip
Does anyone make a correct length 1974 exhaust extension for 2 1/2” exhaust? I am putting the PYPES SGF70 on my ‘74 but even their long tops are too short.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 05-17-2020, 09:08 AM
ladytata's Avatar
ladytata ladytata is offline
I have some old repops, I’ll text you some pics with measurements,
Old 05-17-2020, 01:57 PM
OVERULD's Avatar
OVERULD OVERULD is offline
I used Gardner’s full exhaust package on mine, and they look fine. I posted some measurements and a bunch of photos in my thread, starting on page 5 or 6 and continues for several pages with lots of photos. I had to do a lot of tweaking to get the tips to look the way I remember them looking on the 74 I bought used back in 75, and finally got everything adjusted so that it fits and aligns just as it should.
http://forums.maxperformanceinc.com/...d.php?t=802788
BJ
The Following User Says Thank You to OVERULD For This Useful Post:
Old 05-17-2020, 02:02 PM
Held for Ransom's Avatar
https://pypesexhaust.com/i-13475101-...ong-evt58.html
First, you got the EVT58 tips, right?
I don't know where they get the 20" length from. Tip grows when picture is taken, was only 18-1/2" long.
ID:	540409   Click image for larger version
So long, farewell.
Old 05-17-2020, 05:02 PM
ladytata's Avatar
Here is mine
Old 05-17-2020, 09:11 PM
Aus78Formula Aus78Formula is offline
They are measuring the tip prior to bending, probably how I'd do it too.
Old 05-20-2020, 10:40 PM
3tas4me's Avatar
Yes, I got the longer ones. I was able to compare the PYPES long tip against my original and the are about 2” too short.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 05-20-2020, 10:44 PM
3tas4me's Avatar
BJ
Gardner’s system is a copy of the original so the tailpipes are only 2”. The PYPES system is 2 1/2” throughout. I was hoping someone made a correct length extension in 2 1/2”.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 07-11-2020, 03:11 PM
1qikta's Avatar
1qikta 1qikta is offline
The EVT58 seems to be still available for 74-75 Firebird. The EVT59 is correct for 71-73. Both work with the SGF70 kit.
In the past,, I have added length to the EVT58 with a short 4” reducer sleeve pipe from the auto parts store exhaust section. It brings the back cut of the tip flush with the contour of the base of the bumper.
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to".
