Old 05-14-2020, 02:08 PM
pontorquer's Avatar
pontorquer pontorquer is offline
Default 1974 Firebird Header grilles panel lower brackets ?
My 1974 Firebird is missing the 2 brackets on the bottom part of my header panel under the grilles, does anyone has a picture of what they look like and where they attach or how they bolt on ? Are they reproduced ? Thanks
Bad body shop lost a bunch of parts and hardware
Name:	1974 FB missing lower bracket 001.jpg
Old 05-14-2020, 08:23 PM
Held for Ransom's Avatar
Here you go. Not reproduced, that I know of. May or may not be stamped with PN 492634.
Mine didn't have washers under the bolts in assembly manual picture.
ID:	540220   Click image for larger version
ID:	540221   Click image for larger version
ID:	540222   Click image for larger version
ID:	540226   Click image for larger version
So long, farewell.
Old 05-15-2020, 01:38 PM
pontorquer's Avatar
Thank you so much for the very well detailed pix, they bolt to the rad support. Now the search is on for a set of used ones ...
Old 05-15-2020, 11:02 PM
sd7369's Avatar
sd7369 sd7369 is offline
I have a set of those blasted and powder coated. Send me a message to sd7369@aol.com
