Old 01-19-2021, 03:43 PM
ken66 ken66 is offline
Thanks, Ben. My vac is around 11 in gear at idle. Stopping from speed is not terrible bc there's more vac when I'm just off the gas. I can really feel it backing out of a steep driveway though, for example. Using both feet helps...
Old 01-20-2021, 11:50 PM
63gpman's Avatar
63gpman 63gpman is offline
did you happen to find that write up? Thanks again!
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 01-21-2021, 09:09 AM
ben3843100 ben3843100 is offline
I did locate it yesterday and spent some time adding some notes and additional parts I used to to. I also started putting together a list of the suspension pieces I used like bushings, sways bars, rear links, and front tubular a-arms and where I got them from.
I’ll try and send those out to you today.
Old 01-21-2021, 09:25 AM
Old 01-21-2021, 11:44 PM
Target Car: 1966 Pontiac Catalina / 2+2 with OE manual standard 4-wheel drum. Currently running 17" x 7" Cragar Eliminator 500 aluminum wheels. Converting to 4-wheel power disk brakes. Here is my parts list to this point.
Brake Booster: P/N BM17005-5 (Extra-long studs to fit full size Catalina properly)
Details: 1966 Pontiac Catalina Power Brake Conversion Kit - 9" Dual Diaphragm Booster w/OE Manual Brakes
The conversion kit includes the following:
9 inch Dual Diaphragm Brake Booster
1-1/8 inch Bore Quad Port Master Cylinder
Firewall Mounting Brackets and Hardware ( I ended up not using this for reasons I can go into in another post)
Push rod with Pedal Attachment
3 feet of 11/32 inch Vacuum Hose
Intake Manifold Fitting
Price: $399 / kit
Link: https://www.mpbrakes.com/booster-mas...42408BB08300D3
Disc / Disc or Drum / Drum Combination Valve: P/N VL3359K (not for front disk / rear drum; for disk / disk only)
Details: The kit includes the following items:
Combination Valve for Disc/Disc Applications,
Mounting Bracket with Black Electroplate Finish
Pressure Differential Switch Pigtail
Bleeding Tool
Valve to Bracket Mounting Hardware
Assorted Fittings for Installation
Price: $119 / kit
Link: https://www.mpbrakes.com/pc_product_...C08E2DAD45E44B
Front & Rear Stainless Steel 4-wheel Drum to Disk Conversion Brake Lines from Inline Tube
Notes: I would probably buy bulk stainless brake line and fittings and make these myself next time. I had to modify the rear axle line and custom make the brake master cylinder lines.
Details: These lines are all inverted double flare and match up to the new stainless flex hoses listed below just fine. No adaptors were required.
SMFG70628A 1966 Catalina/Bonneville/Grand Prix Dual Master Conversion Lines For Power Brakes 1
SMFG70628B 1966 Catalina/Bonneville/Grand Prix Dual Master Conversion Lines For Power Brakes 1
SMFG73995 1966 Pontiac Catalina/Grand Prix 1/4" Front to Rear Brake Lines, Stainless 1
SMFG73999A 1966 Pontiac Bonneville/Catalina/Grand Prix 3/16" Left Front Brake Line, Stainless 1
SMFG73999B 1966 Pontiac Bonneville/Catalina/Grand Prix 3/16" Right Front Brake Line, Stainless 1
SMFG74003A 1965-66 Pontiac Bonneville/Catalina/GP 3/16" Rear Axle Line (1 of 2), Stainless 1
SMFG74003B 1965-66 Pontiac Bonneville/Catalina/GP 3/16" Rear Axle Line (2 of 2), Stainless 1
Price: $199.00 (Also available in OE steel for $179.00)
Link: https://www.inlinetube.com - Must call in to order; not listed on website.
Distribution Block, Brake Fluid, 1966 Bonn/Cat/GP, Dual M/C or Power Disc Brakes
Note: I used this because it let me use the Inline Tube disk conversion lines which terminate at the OE brake distribution block mounted to the front driver's side frame rail, but seperate the front and rear brakes into two seperate circuits. If I had custom-made lines I probably would not have used this.
Note: Using this makes the brakes lines look and run more like the factory OE manual brake lines. The two lines enter the top of the distribution block from the master cylinder, a single large line runs to the back, and two smaller lines lead to the left and right front calipers.
Price: $32.99 / each
Link: https://www.opgi.com/brake-systems/p...s-gbc9833.html
Front Disk Conversion Parts
Front Disk Brake Conversion Kit for 1965-66 Full size Pontiac 14" or bigger wheels: Product Code: ZNL R30 6566 Kit
Price: $389.00 / kit
Link: https://scarebird.com/index.php?rout...product_id=251
Front Braided Stainless Brake Flex Hoses
Details: Universal Braided SS Brake Hose, 16" Long with 7/16" Banjo (Includes hardware) Made in USA. 3/8-24 female inlet for inverted flare with 7/16" Banjo Includes: 2 hoses, 2 banjo bolts(7/16-20), 4 copper washers, 2 clips
Price: $37.00/ pair
Link: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Front Disk Brake Rotors
Note: Unlike the rear rotors I purchased, these were not zinc PLATED, but were painted with zinc paint. I was disappointed when the coating came off with brake cleaner. I plan to pull them back off and repaint them to prevent surface rust.
Details: ATL Autosports Performance Brake Rotors. Fits 2006 Dodge Sprinter 3500 [W/285mm Front & Rear Discs ] ATL53028-35DS. Drilled, slotted, zinc-plated (NOT)
Price: $122.38 / pair
Front Disk Brake Calipers (use calipers to fit 1972 GTO per Scarebird documentation; these Wilwoods are designed to fit stock GTOs)
Note: These bolted up to the b-body adaptors from Scarebird just fine, but I ran into two small clearance issues. The calipers are dual piston and the puston bodies are slightly wider than the single-piston calipers the Scarebird brackets are designed for. I had to file the inside hole of the Scarebird brackets so the caliper could move in and out freely.
Note: The second area of interference was inside the caliper. The Dodge Sprinter rotors rubbed on the inside of the calipers slightly when rotating the rotors with the calipers bolted onto the Scarebird brackets. I used a hand file to file a slight depression in side each brake caliper to prevent the edges of the rotor from contacting the inside of the calipers during rotation.
Note: Be sure to follow the Wilwood instruction for bedding the beds to the rotors before you judge brake performance. My brakes felt much better after bedding the pads.
Details: Wilwood Dual-SS Piston Forged Aluminum Brake Calipers, 1964-72 A-Body, D-52, black powder coat (also available in red)
Price: $384.99 / kit (includes mounting bolts, BP-10 brake pads)
Link: https://www.opgi.com/brake-systems/d...d-ch29044.html
Front Disk Brake Pads
Details: Wilwood BP-10 high-friction pads for D-52 dual-piston calipers above
Price: $66.36 (this is approximate replacement cost; these are INCLUDED with Wilwood D-52 brake caliper kit)
Link: https://www.wilwood.com/brakepads/br...emno=150-8939k
Rear Disk Conversion Parts
Rear Disk Brake Conversion Kit for 1949-70 Pontiac, Oldsmobile: Product Code OPR
Details: Includes brackets, hardware, brake shoes, etc.
Price: $295.99 / kit
Link: https://scarebird.com/index.php?rout...&product_id=80
Rear Braided Stainless Brake Flex Hoses (hard lines on rear axle to metric Chevy Citation rear disk calipers with 10mm Banjo)
Universal Braided SS Brake Hose, 15" Long with 3/8-24 female inlet for inverted flare to 10mm Banjo (Includes washers, banjo bolts, hardware) Made in USA by The Stop Shop
Price: $37.00 / pair
Rear Braided Stainless Brake Flex Hose (central hardline from rear frame to center of rear axle with distribution block for axle hard lines)
Universal Rear Braided SS Brake Hose, 14" Long with mounting block. 7/16-24 female inlet for inverted flare.
Attached mounting block with 2 - 3/8-24 ports for rear axle brake lines
Price: $18.75 / each
Rear Disk Brake Rotors
Details: Performance Drilled Slotted & Coated Disc Brake Rotor Pair for GM (1994-1996 Impala / Caprice Rears) by AM Autoparts. 5 Lug, Diameter: 11.61 in. (295mm), drilled, slotted, zinc-plated, integrated drum parking brake
Note: These were zinc plated and seem to be nice rotors
Price: $59.79 / pair
Rear Disk Brake Calipers (1980-1985 Chevy Citation / Citation II Brake Calipers FRONT)
Details: NAPA Total Eclipse Remanufactured Front Right / Left 2" single-piston OE cast-iron Brake Caliper with Hardware - Semi-Loaded - Black-Coating - metric M10 banjo
REMAN/BRAKE CALIPER: Part #: CAL SE4682 Qty: 1 $31.24 /each + $11.11 core /each
REMAN/BRAKE CALIPER: Part #: CAL SE4681 Qty: 1 $31.24 /each + $11.11 core /each
Price: $84.70 / pair
Link: https://www.napaonline.com/en/p/SEBSE4682 / https://www.napaonline.com/en/p/SEBSE4681
Rear Disk Brake Pads (1980-1985 Chevy Citation / Citation II 2.8L 173cid V6 FRONT)
Note: There seems to be a large variation of pad thicknesses. If you have issues with the rear calpers with pads fitting correctly, you may need to sand the pads down a bit. I believe this may be related to the location of the rear axle flange relative to the rearend housing flange. I believe certain people run into rubbing problems because their rear axle bearings are pressed on either too far in or out on the axle which changes where the rear disk ends up inside the rear calipers. I had to sand my outside flange a little bit to prevent rubbing, but only on the drivers side.
Note: I ordered a set of AC Delco pads and they were MUCH thicker than the CENTRIC pads I ended up using.
Details: CENTRIC 50002890 (Premium) PQ PRO Front
Price: $22.79 / set
Link: https://www.rockauto.com/en/moreinfo...66&jsn=1&jsn=1
Rear Axle Studs
Note: I replaced all of my rear axle studs to account for additional disk brake thickness (probably less then 1/8' thicker) and the aluminum wheels (and their thicker hubs) I'm using. I removed and installed them with a ball joint press.
Details: Dorman 610-080 Wheel Stud 3.6 x 2.4 x 2.2 inches
Price: $17.08 / set of 10
Brake & Wheel Hub : Brake Backing Plate Gasket (1965-1970 Catalina / Full-Size)
Note: Seals between axle flange and Scarebird disk brake adaptor plates.
Details: FEL-PRO 13831 {#760023, 9778249} Backing Plate Gasket; (4-bolt holes); 2-5/8 inch I.D.
Price: $1.59 each (need 4?)
Link: https://www.rockauto.com/en/moreinfo...119756&jsn=260
Parking Brake: Stainless steel replacement rear parking brake cable for 1965-1966 Catalina/Grand Prix
Park Brake Cable, Rear, 1965-66 Catalina/Grand Prix
Price: $62.09 (need 2)
Link: https://www.opgi.com/brake-systems/e...x-gc03882.html
Rear Disk Brake Install Notes
You can access the bolts and remove rear drum brakes with backing plate as an assembly, but I had to disassemble one of the shoes to remove the parking brake cable and remove two bolts on the backside of the drum backing plate that held the parking brake cable to the backing plate. Disconnect brake line from wheel cylinder or cut original brake line near fitting. (Keep line for comparison to new lines)
Slide out axles being careful not to damage the axle seals. (I replaced both of mine)
Press out old axle studs and press in new longer studs (I used a large ball joint press)
Pry open metal tabs that hold original brake lines to rear axle and bend old brake line out of the way.
Trial fit new Inline Tube stainless steel conversion line. There is enough length in them to bend the end that would normally be routed to the rear wheel cylinders into a broad twisted S shape that will reach the new metric caliper hose bracket. If you go with custom lines, you should add a couple inches of length to the factory line length which would allow you to use both of the original tabs on the axle. I believe in-line Tube will make custom lines for you as well.
<INSERT PICTURE>
Clean the original special axle flange bolts and nuts and scrape any gasket material off of the rear axle flange.
Install the special bolts in the axle flange and install a new axle flange seal.
Install new Scarebird disk brake bracket with caliper mount at rear of car. The brackets are marked so you know which side each is to be installed on.
Install new axle flange seal over bolts on the outside of the Scarebird bracket.
Slide the axle into the rearend housing and into the differential
Note: may want to measure the position of the rear axle bearing relative to the axle flange in case you have issues with the rear rotors rubbing on the brake pads.
Slide axle retaining ring up against Scarebird bracket (with new seal) and install original nuts. Torque to ?
Install brake rotor. If brake rotor holes will not slide easily over lugs, use round hand file to slightly enlarge holes in each rotor.
Install caliper with bleeder pointing up and torque mounting bolts to spec
Install brake hoses from bracket to hardlines on axle
For the parking brake mods, I purchased new stainless L & R rear parking brake cables and proceeded to carefully cut off the flanges that would normally bolt to the OE drum brake backing plate.
I then cut off the crimped on brass ends of two old rear drum brake hoses, cut a slit in them so they could be slid over the new parking brake cables, drilled them out to fit over the outer parking brake cable sheath , and used them as a flange to terminate the new cables at and attach them to the new Scarebird backup plates using OE clips. No other mods were required to the parking brake cables and they have been working great.
Front Disk Brake Install Notes
I removed everything from the front suspension and painted it. I also replaced all bushings with polyurenthane, both upper and lower balljoints, and all springs during the disk conversion.
Mount the new aluminum Scarebird hub with new bearings as specified in Scarebird instructions.
Install Scarebird brackets per instructions and torque bolts to spec
If you're using the GTO dual-piston calipers as mention in the parts list, file the Scarebird bracket to fit the wider dual-piston caliper body to ensure it moves in and out freely when mounted.
Trial fit new brake rotors and slightly enlarge brake rotor wheel stud holes if required
Power Brake Conversion Notes
Haven't gathered my thoughts on this yet. I ended up mounting the aftermarket booster directly to the firewall without the MasterPower brakes-supplied adaptor for a more factory look and then modified two factory brake pedals to create one long OE-style manual (narrow) brake pedal. I can supply more information on the why's and how's of this in a different post.
The Following User Says Thank You to ben3843100 For This Useful Post:
Old 01-22-2021, 12:41 AM
63gpman's Avatar
That's awesome! Thanks for the list and taking the time to go through that, much appreciated!
Brad Hansen
Old 01-22-2021, 10:24 AM
Strange, the forum must remove links from posts. I see all of my links are gone when reading my parts post. If anyone want a copy of the document with links, I can send them one.
Old 01-22-2021, 10:51 AM
misterp266's Avatar
Links show up for me and yes, they work. Thanks!
" Darksiders Rule "
Old 01-23-2021, 01:49 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
That is some amazing information Ben, thank you for taking the time to post it all! I just a few minutes ago told a newbie that this place has great folks & great information...This thread & you are examples of both!
I am just about to buy the MP. Brakes kit for my 66 Cat Conv. I am not to concerned about the vacuum issue as I already know I will need the pump! LOL
I am getting the complete front disk kit with a chrome booster & painted master.
God Bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Pontiac Transporter
Bills' Auto Works Est 1983 & still going strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Ambassador Custom Lemans
1957 Chieftan 2dr HT
1964 Grand Prix
1966 Catalina Conv. 421
1966 Ambassador DPL 2dr HT
1966 Ambassador Cust. 2 DR HT
1967 Marlin
1967 Toronado
1973 Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
Old 01-25-2021, 02:17 PM
God Bless
Bill
Sounds great and glad I could help! I had to perform quite a bit of searching to figure out all of the parts I needed for my car. There was no one-stop shop for the information. Curious, is your car currently an OE power brake-equipped car? Just wondering if you're converting to PB or have OE power brakes. In case you're not aware, there are three pedal assembles for at least the '66 Pontiac full-size cars (possibly '65 as well), and what your car has currently does affect what you should order and how you want the engine compartment to look.
If you're converting to power brakes and currently have a manual brake pedal set, it would look more "factory" and give you more room in the engine compartment if you ordered a MasterPower kit for an OE power brake car and then changed your pedal assembly to a factory power brake assembly. This would eliminate the pedal ratio adaptor bracket that would sit between the MasterPower booster and the firewall to account for your shorter OE manual brake pedal.
If you're aware of this already, great. If not, let me know and I can provide pictures to show what I'm referring to.
- Ben H.
Old 01-28-2021, 07:48 PM
- Ben H.
Yes Ben,
Mine was originally a power drum brake car & after reading your earlier post about how you removed the bracket & then had to figure out the pedal & rod, I am glad mine was power because it does really look better mounted right to the firewall! Trevor from MP Brakes actually asked me that directly (about how the booster was mounted) I ordered my kit Monday with a chrome booster, painted master & the disc conversion kit, but did not upgrade to the cross drilled & slotted rotors..
Again thanks for the detailed thread! Below is mine, it is further along, but this was the last picture. Tough building 3 cars at the same time when I don't have time for one, but I am heavily addicted!
God Bless
Bill
Name:	IMG_20190706_132559684_HDR (800x450).jpg
1964 Grand Prix
1967 Marlin
1967 Toronado
1992 Jag XJS Conv
1992 Jag XJS Coupe
The Following User Says Thank You to Bills Auto Works For This Useful Post:
Old 02-02-2021, 10:15 AM
Yes Ben,
God Bless
Bill
Yes Ben,
God Bless
Bill
Looks good! I’m sure it will be awesome when you’re done and a convertible to boot! You are definitely more ambitious than I, although I DID hand scrape and paint my entire undercarriage and suspension last spring during COVID. ;-)
Old 02-05-2021, 01:44 PM
GT182's Avatar
GT182 GT182 is offline
I went with Scarebird for the front disc brake setup on my 66 GTO and I'm very happy with it. No changing out the drum spindles with his kit. The dual master cylinder was thru Pirate Jack. No power brakes but you wouldn't know it. It's so much better now than with drum brakes up front.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-09-2021, 05:51 PM
misterp266's Avatar
Just received my Wilwood front caliper kit. Got it through Walmart for only $317.
https://www.walmart.com/ip/Wilwood-D...Rotor/51564450
Already have my Scarebird brackets installed on my ‘63 Safari so need to check the clearance but that’s OK.
Gary, which M/C did you get? I was looking at the aluminum #MC1312A. I am also running manual brakes.
" Darksiders Rule "
Old 03-15-2021, 08:36 PM
I got a couple of deliveries over the last couple of days...Kind of like Christmas except for the paying part!
My Master Power Brake front disc brake kit with Chrome booster for the 66 Cat Conv & my rebuilt & re-plated booster & cap for the 64 Grand Prix. I was all set to use "Booster Dewey" on a recommendation from another member when I happened to come across Mike @ Brake Boosters in Cal., spoke to him on the phone & liked him immediately. He did a very nice job.
God Bless
Bill
Name:	20210303_140001 (800x600).jpg
ID:	562735   Click image for larger version
Name:	20210315_174730 (600x800).jpg
1964 Grand Prix
1967 Marlin
1967 Toronado
1992 Jag XJS Conv
1992 Jag XJS Coupe
Old 03-16-2021, 08:54 AM
God Bless
Bill
Awesome! Looks like you’re in for some fun & can’t wait to see some pics. I’ve been busy chipping away at rebuilding my doors over the last two months & will also be making some additional mods to my brakes as well.
Old 06-18-2021, 04:54 PM
6566Poncho 6566Poncho is offline
I have the Scarebird FRONT and REAR disc brake kits on my 66 Catalina Ventura I am having an issue with the rear disc brake ebrake pad. I am using the recommended AC Delco rotor and the epad that Scarebird supplied. The ID of the rotor is 7.5". The epad is the basically the same size (10/100 less than rotor - leaves only 5/100 around rotor- seems like too small of tolerence-??). After test driving - noticed epad was totally dragging. Removed and inspected epad (on both sides) and the pad was chattered from one end to the other. Could barely turn the rotor by hand with the ebrake pad installed. I removed the epad and test drove and no problems with balance of setup. I contacted Scarebird and provided them with information they requested and they say all is fine and should be working without issue. No other remedy was offered. Has anyone else had an issue with the ebrake setup and have any possible solutions?
  #38
Old 06-18-2021, 05:00 PM
Originally Posted by 6566Poncho View Post
...No other remedy was offered...
Did you pull off the parking shoes and test in the rotors like we asked you to?
  #39
Default '66 big car disc brake conversion
I have the Scarebird systems front and back on my ‘66 Catalina as well. I used the provided parking brake pads and cross drilled and slotted rotors I purchased off of Amazon. I did not have any problem with clearance or drag when adjusted according to the Scarebird instructions and they work great. It almost sounds like the material on the circular shoes you received are thicker or the internal drum in the disk is machined to a smaller diameter. Strange.
I have seen quite a variance in rear disk brake pad thickness. The first set I purchased from RockAuto fit ok (I did sand the inside pad slightly), but the friction material on the replacement set I picked up from NAPA and tried to mount was was way thicker and I couldn’t even mount the caliper over the rear disks.
  #40
Old 06-18-2021, 05:21 PM
yes
