Old 07-03-2020, 06:39 PM
jscheublein jscheublein is offline
Default 1964 pontiac Catalina tilt column rag joint
I bought a tilt column for my 1964 Catalina - but the rag joint part that goes over the spline at the end of the column shaft is missing. Guess it got left on the steering box. Does anyone have one for sale? Jim 209-601-4408 Thhanks
Old 07-03-2020, 06:51 PM
stevep's Avatar
stevep stevep is offline
It isn't the same as the straight column's rag joint?
Did you also get the firewall plate and bracket?
Old 07-03-2020, 07:39 PM
marxjunk marxjunk is offline
i know on 65-68 tilt has its own rag joint...i have some early tilts that have a bolt on rag, but dont know enough or have a non tilt to compare
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-03-2020, 08:28 PM
Default 1964 catalina tilt upper rag joint housing
On the straight column the flange is forged as part of the steering column shaft. On the tilt column the end of the shaft is externally splined and the end to attach to the rag joint is a flange plate that is similar to a cone shape and has internal splines to slide over the shaft and a bolt claps it to the shaft. Sounds like you might have one or more.
Thanks Jim
Old 07-05-2020, 07:44 AM
chrisp chrisp is offline
I have 1 & will dig it out after you send a pm with your email.
