Things that make me go Hmm
OK I know 3 speed on the Column was available in 1966,
as well I have seen shifter delete plates on consoles but Woodgrain in '66 ??
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
On the horn trim as well? definitely Hummmmm
Just my opinion on the shiftless console and wood grain ....... Silly / Ugly.
Just a little over 37,000 Original mile Survivor. Exterior is beautiful!. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Is the radio delete plate correct?
Honestly, given the litany of tacky things that people do to their GTOs, I find this pretty low on the scale of offensiveness. Definitely not my cup of tea, but far from the worst I've seen.
Pretty odd color combo, too.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
RADIO DELETE 65-66
Is correct.
The console has been over-embellished IMHO and as pointed out the horn bar as well A stock ribbed console top along with a flat black shifter plate would go a long way in such a striking '66 interior. I thought I had more file images of the shift delete but haven't been able to locate them. Below are Radio Plates.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:16 AM. |
Gorgeous exterior! Where are these pics from? Knowing more about the car the wood grain “day 2” changes make sense.
Jeff, do you know if the cars that got the heater delete used a flat plate on the firewall or the standard air box? One of my 66's has the heater delete plate but has the standard non-a/c box.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
The ones I have seen had nothing but the block off plate.
I had great images of one exported to Hawaii, If I recall the plate was very similar to the aftermarket pieces being offered.
