Old 06-26-2020, 03:35 PM
6t5gto 6t5gto is offline
Default fuel pump plating
What is the proper finish for a 4512/6550 3 piece fuel pump after restoration? I spoke to "Then and Now" and "Arthur Gould" and both say they bead blast the whole unit and either can leave it bare or clear coat it. They do not do any plating at all. I have seen pictures from Jim Mott restorations and his pumps are bead blasted lower and middle but the top piece is yellow dichromate. Scott Tiemann pics show the lower and bottom bead blasted also but the top is more like a grey finish. Does the top need to be plated first and then sent out to be restored or does someone do it from beginning to end including any plating that needs to be done?
Old 06-26-2020, 04:16 PM
Dick Boneske's Avatar
The '64 and '65 pumps were dichromated yellow like the Tripower carb bodies. The bottom steel cover can be zinc plated. I think that should be bright zinc (silver). I believe the top screws should be black like the carb airhorn screws.
Others please reply if you have better info. .
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-26-2020, 05:25 PM
Jim Mott restored fuel pump. Yellow dichromate top with bead blasted middle and lower? I just checked my 4512 fuel pump and it is all aluminum. Can aluminum be dichromated or zinced?
ID:	543453   Click image for larger version
Old 06-26-2020, 05:27 PM
The bottom and middle almost looks like it is sprayed silver.
Old 06-26-2020, 09:08 PM
Scott Tiemann pump. Top is plated grey.
Old 06-27-2020, 09:59 AM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
This is a NOS/AC fuel pump #6550. This is a replacement part and sometimes these parts differ from those used on the assembly line, especially if they are purchased well after the model year they were used on. However, the box has a print date of 64 so my guess is this is the correct color.
The pump arm is black maybe with some type of phosphate coating. The top of the pump has a flat gray/green or green/gray finish—take your pick; the surface is very smooth. The bowl has a silvery finish and appears to be “as cast” pot metal or aluminum. The bottom cover has the same finish as the top. All the screws appear to be cad plated—yellow??-gold??
ID:	543520   Click image for larger version
ID:	543521   Click image for larger version
ID:	543522   Click image for larger version
ID:	543523   Click image for larger version
The Following User Says Thank You to 64-3Deuces For This Useful Post:
Old 06-27-2020, 10:04 AM
64-3Deuces's Avatar
A few more pics. These on car pics are from an 8K mile 64 GTO survivor. You can see the pump has the same finish as my NOS pump though the plating on the survior may have degraded somewhat over the years.
ID:	543525   Click image for larger version
ID:	543526   Click image for larger version
Old 06-27-2020, 12:26 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
64-3Deuces offered a perfect explanation of the 6550.
I appreciate he took the time to share his text and photos.
Here is the NOS 6550 I have.
Chris.
ID:	543543   Click image for larger version
ID:	543544   Click image for larger version
ID:	543545   Click image for larger version
ID:	543546   Click image for larger version
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 06-27-2020, 12:31 PM
60sstuff's Avatar
The number 64 is cast a couple times in this unit of mine.
ID:	543548   Click image for larger version
ID:	543549   Click image for larger version
ID:	543550   Click image for larger version
ID:	543551   Click image for larger version
Old 06-27-2020, 12:52 PM
64-3Deuces's Avatar
Chris, thanks for your post...Good to see another pump that backs up what I have as NOS.
Your pump is stamped JD and mine is stamped FE. Have any idea of what these mean...assembly plant or assembly line, casting mold, or some internal production tracking???
Old 06-27-2020, 12:56 PM
This is how I remember them. Never seen one "painted".
Old 06-27-2020, 01:09 PM
The 1st letter is the month and the 2nd is the year. FE June 1965. F 6th month E 5th year from 1960. JD is October 1964.
Old 06-27-2020, 01:17 PM
64-3Deuces's Avatar
Good to know, thanks for the info...
Old 06-27-2020, 02:55 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Also note a brass fitting is supplying to the carb and a steel fitting is fuel from tank.
"Bill"!
Old 07-21-2020, 05:30 PM
8LUG 8LUG is offline
Any 4512 photos/originals or restored . This site replates & rebuilds http://www.classicpreservation.com/fuelpumpkits.html
Old 07-21-2020, 07:42 PM
I did speak to him, but he is about 4 months back logged.
Old 07-21-2020, 09:57 PM
Old Man Taylor's Avatar
Chris.
That's the way I remember mine, but I'm sure it had quite a few miles on it before I really paid much attention to the color.
Old 07-23-2020, 05:56 PM
So nobody got a 4512 to show the coloring just the 6550 here's a helpful video https://www.youtube.com/watch?v=TjMX39mOK1E
Old 07-26-2020, 08:38 AM
work in progress/ lotta textures ,smooth to ruff, colors also AC 4512's. Just like the license plate light search.
Name:	4512 fuel pump.jpg
ID:	545824   Click image for larger version
Name:	fuel pump 4512.jpg
ID:	545825   Click image for larger version
Name:	license plate lights.jpg
Old 07-26-2020, 11:12 AM
8LUG, Do you see many date codes on your 4512 fuel pumps? If so, do you have a J, K, L, or M of 64 and would it be for sale? Doesn't even have to be a complete unit, just the dated housing.
