Old 04-07-2020, 01:03 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
Default 69 gto dash wood panel re chrome the plastic edges
hi
was curious , i'm in canada trying to find a place that still does this type of plating work.
i do see that ames sell this:
https://secure.amesperf.com/qilan/De...A&web_access=Y
Molotow - Liquid Chrome Marker
I assume this product works which is why they are selling it.
https://www.deserres.ca/en/molchrome
Has anyone tried this before?
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 04-07-2020, 08:29 AM
mrennie's Avatar
mrennie mrennie is online now
Have not tried that product or seen any posts about it. Looks interesting.
If you have not seen this thread, take a look:
http://forums.maxperformanceinc.com/...d.php?t=754763
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 04-08-2020, 02:21 AM
kyle_blake's Avatar
thanks i'll read the thread closer, it's too bad all the photos with that bucket company went pay only... hopefully i can find what product they were talking about, I'll read again and not skim.
Old 04-08-2020, 03:45 PM
kyle_blake's Avatar
Ahh I read it again. I see.
I phoned Ames they said the PEN works well for this type of dash section that i am restoring. If it was a larger area like a different dash.... then yah it wouldn't work.
I read your link, THANK YOU!!! THAT IS AWESOME!!! IF I ever needed to I even have the kylon paint in my garage and just would need buy the spatz stuff
Old 04-08-2020, 06:36 PM
Big Bear's Avatar
Big Bear Big Bear is offline
My son put me on to the marker. He bought it from Hobby Lobby to do the chrome trim on model cars. Just finished trimming my Z-28 dash. It looks close to chrome. I'm happy with it.
Old 04-08-2020, 07:26 PM
Big Bear's Avatar
Here are some pictures. Not super clear but shows what it looks like.
ID:	536735   Click image for larger version
ID:	536736   Click image for larger version
ID:	536738   Click image for larger version
Old 04-08-2020, 08:19 PM
kyle_blake's Avatar
Awesome, thanks for sharing...
I'm sold on it.... did you wash it and scuff off all the old stuff off or just go right over all the old stuff?
Old 04-08-2020, 09:18 PM
Big Bear's Avatar
No scuffing. Wiped lightly with thinner and applied. Marker comes in different widths. 1mm was too narrow and had to make several strokes for coverage. 2mm worked better.
Old 04-08-2020, 09:44 PM
mrennie's Avatar
Big Bear,
Do the marker results look like they will be as good as paint, or do you think it will rub off easily?
I still have the edges of my dash and vents to do and bought the Spaz Stix paint, but disassembly, masking, and unmasking to do the edges seems like a real PITA.
Michael
Old 04-08-2020, 10:46 PM
kyle_blake's Avatar
I agree 2mm is what I was going to buy. Mine has previous paint job . I'm going to take the wood sticker off then lightly use isopropyl around all the edges to clean off all the old plated chrome. I will then give it a nice spray of the black. The edges leading up to where the pen chrome is applied will look nice if they are black, I figure. I hope ... I have a couple test pieces. Hopefully the chrome pen over the black paint ( it was mentioned in that long article that black paint helped with the spaz stik, who knows if it does with this. I just wan the edge on inside to be black. The very top edge is actually chrome plated as well I noticed!
Anyway if someone things don't bother with black, I'm not opposed to following their lead.
Old 04-08-2020, 10:57 PM
Big Bear's Avatar
If rubbed on it will dull to silver look but not chipping off. I did it free hand taking long strokes. No masking. When liquid it flows and stays on the raised lip. If it does'nt turn out the first time have a cloth dampened with thinner ready, wipe it off and try again.
The Following User Says Thank You to Big Bear For This Useful Post:
Old 04-21-2020, 02:50 AM
kyle_blake's Avatar
Hi,
Well the job got done . That pen is awesome, affordable and it works. i decided not to use black anywhere.
I used some fine sand paper to take off the old chrome. That was a mistake , it ended up creating some lines and was too low of a grit. Either leave the old stuff on or I maybe use some sort of liquid remover stuff? Wish I knew but still turned out pretty good, I just multiple coats.
It's tricky to use the pen and run it down the sides but long strokes seemed to work ok.
I bought some new stickers . the fit is about 99% good. a little short in places.
over all the chrome also works on the other chrome pieces, like lighter or lights quite well. it's a good touch up.
you can see my old set verses the new restored set.
any way that concludes my project!!!
ID:	537978   Click image for larger version
ID:	537979   Click image for larger version
ID:	537980   Click image for larger version
