73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 05-14-2020, 06:06 PM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Sending unit ground
Hey, I'm just wondering if there is a specific place for my fuel sending unit to be grounded. Cause all I hear when I turn her over is the fan spinning but then again I am a newbie.
Old 05-15-2020, 01:51 AM
Brian Baker's Avatar
It's typically grounded to the underside of the trunk floor pans, just above the fuel tank, but I am confused about your entire question.
Old 05-15-2020, 01:59 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
Me too Brian. Sounds like the engine isnt getting any fuel?
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 05-15-2020, 10:22 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
The fuel sender in the tank is grounded from the factory with a single wire to the chassis sheet metal by the trunk. If you have installed an electric fuel pump sender, you will still need to ground it.
Old 05-15-2020, 11:13 AM
I'm talking about the sending unit right below the carb. Under the water outlet I think my dad and I got the sending unit in the tank good when we did the tank a couple of years ago plus last time we did try to start her she was getting fuel to her. But keep in mind that this was a couple of years back.
Old 05-15-2020, 11:47 AM
Grand73Am Grand73Am is offline
I still can't tell what you mean. There's no "sending unit" under the carb and water neck. There's the water pump. There's the fuel pump further down on the driver side of the engine. But none of that is electrical. So, can you explain what this "sending unit" is supposed to be for on your engine? What is it supposed to do?
Steve F.
Old 05-15-2020, 12:18 PM
Sorry it's the oil pressure sending unit is the unit I'm talking about. I also have an olds 350 in my 77 lemans
Old 05-15-2020, 12:34 PM
Okay. That makes a big difference, since the Olds oil pressure sender is different from the Pontiac. But, the Olds oil sender unit is grounded just by being screwed into the engine. Don't use any teflon tape on the threads where it screws in, since that could interfere with the grounding. The wire that should be plugged onto the oil sender is blue.
Steve F.
