Old 06-19-2020, 07:11 AM
Jeff Hamlin's Avatar
Question Things that make me go Hmm
OK I know 3 speed on the Column was available in 1966,
as well I have seen shifter delete plates on consoles but Woodgrain in '66 ??
Old 06-19-2020, 10:23 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
On the horn trim as well? definitely Hummmmm
Old 06-19-2020, 10:49 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
Just my opinion on the shiftless console and wood grain ....... Silly / Ugly.
Just a little over 37,000 Original mile Survivor.
Exterior is beautiful!.
Chris.
ID:	542711   Click image for larger version
ID:	542712   Click image for larger version
ID:	542713   Click image for larger version
Old 06-19-2020, 11:00 AM
Bluesugar Bluesugar is offline
Is the radio delete plate correct?
Old 06-19-2020, 11:05 AM
ZeGermanHam's Avatar
Honestly, given the litany of tacky things that people do to their GTOs, I find this pretty low on the scale of offensiveness. Definitely not my cup of tea, but far from the worst I've seen.
Pretty odd color combo, too.
1998 BMW 328is (track rat)
Old 06-20-2020, 06:54 AM
Default RADIO DELETE 65-66
Is correct.
The console has been over-embellished IMHO and as pointed out the horn bar as well
A stock ribbed console top along with a flat black shifter plate would go a long way in such a striking '66 interior.
I thought I had more file images of the shift delete but haven't been able to locate them.
Below are Radio Plates.
Old 06-20-2020, 07:37 AM
Sloan66's Avatar
Gorgeous exterior! Where are these pics from? Knowing more about the car the wood grain “day 2” changes make sense.
Old 06-20-2020, 07:46 AM
Mike Davis's Avatar
Jeff, do you know if the cars that got the heater delete used a flat plate on the firewall or the standard air box? One of my 66's has the heater delete plate but has the standard non-a/c box.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 06-20-2020, 07:56 AM
The ones I have seen had nothing but the block off plate.
I had great images of one exported to Hawaii,
If I recall the plate was very similar to the aftermarket pieces being offered.
Thread Tools
Display Modes
