Old 03-12-2024, 08:06 AM
nh68gto's Avatar
nh68gto nh68gto is offline
Question Help picking a converter.
Hey all. Need help picking a converter. Very little to no knowledge on them. lol
69 GTO 3:23 gears, cower cam, .040 400, rpm intake.
Using 200-4R. Just a street driver, zero track use.
Not sure other info needed.
Thank you.
Send it! It’s going home on a trailer.
Old 03-12-2024, 08:07 AM
nh68gto's Avatar
Something budget friendly too please
Old 03-12-2024, 10:48 AM
Pontiac Performance Author
cam specs would help
The Following 2 Users Say Thank You to KEN CROCIE For This Useful Post:
Old 03-12-2024, 02:07 PM
nh68gto's Avatar
Crower cam is 60243.
INT/EXH - Dur @ .050” Lift: 228°/235° RR: 1.5/1.5 Gross Lift: .479”/.494” LSA: 112° RPM: 1600-1800 to 6200 Redline: 6500
Old 03-12-2024, 03:14 PM
Sun Tuned Sun Tuned is offline
Smartest thing you could do is to give Cliff Ruggles a pm on here.
Bought several converters from him and every one was dead nutz on the money!
He knows what he’s doing.
Blindingly fast shipping also.
Old 03-12-2024, 04:48 PM
brad01 brad01 is offline
I am running that cam ! Just FYI you need compression for that cam and I'm zero decked running 10.75 to1 461 edelbrock heads with 1.52 rockers. I had Coan engineering in Indiana make me one in early 2022 coa-20211-4 and I love it. Stock tires 225/70/14 on the rear and it burns them off when i get into it. It has the original 10 bolt safe-t-track but I have the small tire so them break free to not stress the rear too much.
Old 03-12-2024, 05:07 PM
Good converter = $800
Okay budget converter = $300 - $400
So that leaves out a custom converter from Cliff.
Your best bet on a budget would likely be something along the lines of a Hughes GM25.
For myself I always spend the money for a quality custom converter. Your driving pleasure and satisfaction should matter enough to spend a little more rather than regret buying cheaper and never being truly happy.
Old 03-12-2024, 05:20 PM
nh68gto's Avatar
Thanks bman. I understand, but unfortunately some house holds especially in this economy don’t have thousands at a time to put into a project. Some do need to do what is affordable and not the very best so we can still enjoy the hobby.
I do appreciate the info !!
Old 03-12-2024, 06:16 PM
nh68gto's Avatar
I currently have B&m 20412 in the car. Is that no good?
Old 03-12-2024, 07:09 PM
You would do well to pm cliff…
His converters he sells are very competitively priced.
Add to that the fact that they work first time out of the box like their supposed to, for a Pontiac engine, that saves time and aggravation having to pull the damn thing back out a second time because the converter builder “oopsed” the first time….
That alone is worth $$$.
We’ve used quite a few manufacturers at work for quite a few projects, and the only 3 that did what they were bought to do …came from Cliff. Not saying I’m trying to be a paid shill advertisement for him, I’m just saying the stuff flat works like advertised.
No more, no less.
Old 03-12-2024, 07:23 PM
nh68gto's Avatar
I have.
Ty.
Old 03-12-2024, 08:00 PM
77 TRASHCAN's Avatar
I agree with Bob and Bart.
One of the biggest "bangs" for the buck is a custom torque converter made specifically for your combination.
Another point is that, Pontiac converters need different properties than the Chevrolet World stuff does.
Save up, if you have to!!!
Have fun with that cool car, in the "Shire!!!
Jeff
Shut it off
Shut it off
Jeff
Shut it off
Shut it off
Old 03-12-2024, 08:15 PM
why not try the B&M you have. The description in The B&M catalog closely matches your engine specs.
Old 03-12-2024, 10:03 PM
Dragncar Dragncar is offline
Call Lane at PTC and buy what he recommends. Or Cliff.
A converter is one place you do not want to cheap out.
Old 03-12-2024, 10:11 PM
Jay S's Avatar
Jay S Jay S is offline
The 20412 B&M converter won’t work in the 200R4. It is for a TH350 or TH400.
200R4 has a lower first gear, doesn’t really require much of a stall with street tires, you could just run a stock converter if your on a budget. Reman is less than $150.
The Following User Says Thank You to Jay S For This Useful Post:
Old 03-13-2024, 05:47 AM
nh68gto's Avatar
What’s PTC ?
Old 03-13-2024, 08:23 AM
max 93 max 93 is offline
Are you looking for a lock up or non lock up ?
Old 03-13-2024, 09:21 AM
nh68gto's Avatar
No idea. Lol
Old 03-13-2024, 09:53 AM
Steve C. Steve C. is offline
Make sure the company that builds the 200-4R transmission knows what type of converter will be in use.... lock-up or non-lock up.
Old information here:
