Old 05-28-2020, 05:08 PM
charlie66's Avatar
Default 1964 dash tech
Does anyone know how to make one of these tachs work for a 4 cylinder?
I was thinking if the signal was changed with less power or changing around wires ?
I would appreciate it if someone could shed some light on this for me.
Thanks....
My Half AN Injun.....
Old 05-28-2020, 05:25 PM
charlie66's Avatar
I thought being i had my a digital 6 box set on 4 cylinder that it would take care of the tech being synchronized..
Old 05-28-2020, 05:37 PM
My assumption Charlie is that most Tachs work off of coil firing pulses.
Where do you have the 64 Tach reading the signal?
Old 05-28-2020, 08:54 PM
shaker455's Avatar
Factory Tach ?
Servicing the Pontiac community over 20 years
Old 05-28-2020, 09:23 PM
Charlie has a 1964 A-Body and his 1st post says 64 Tach
so I AM ASSUMING a factory 90 degree sweep dash tach.
Know really nothing about the Pontiac Tachs except mine works and always has with a Points distributor.
Old 05-28-2020, 10:36 PM
charlie66's Avatar
It pluged into the MSD box.
charlie66's Avatar
Originally Posted by shaker455 View Post
Factory Tach ?
Yes
Old 05-28-2020, 11:19 PM
64speed's Avatar
64speed 64speed is offline
What 4 cylinder do you have in a 64 Abody?
Old 05-28-2020, 11:47 PM
charlie66's Avatar
1961 194.5 ci Pontiac from a tempest..
Old 05-29-2020, 12:45 AM
64speed's Avatar
I have to ask why
Old 05-29-2020, 08:29 AM
shaker455's Avatar
Originally Posted by charlie66 View Post
Yes
Did it ever work for you before?
all the old factory tachs I've seen are pretty slow.
I did think this tach in pic was a neat idea for my GP, it was installed in place of the clock.
Old 05-29-2020, 08:58 AM
flat-bill flat-bill is offline
Default factory tachs
I think, but could be wrong about this, that the tach reads pulses from the ignition. Your four will put out 1/2 the pulses for a given rpm and give an incorrect rpm on the tach. Billk
Old 05-29-2020, 09:02 AM
charlie66's Avatar
I have to ask why
Why not?
The Following User Says Thank You to charlie66 For This Useful Post:
Old 05-29-2020, 09:08 AM
charlie66's Avatar
It worked great. It still works but at half the rpm as it actually is..
Heres what i got...
Old 05-29-2020, 09:10 AM
charlie66's Avatar
Thats whats happening.
Do they make an inline converter ?
Old 05-29-2020, 09:18 AM
charlie66's Avatar
I have to ask why
Here it is
Old 05-29-2020, 09:32 AM
shaker455's Avatar
Charlie,
Your tach wire brown? does it have any resistor built into the wire?
If I remember correctly that 4-cyl is what that car came with so why can you not simply take the wire directly to the coil?
Old 05-29-2020, 09:37 AM
Charlie, you are not giving 64 speed the whole story.
Charlie's 4 cylinder turbocharged engine make about 800 hp at 30+ pounds of boost pressure. So the "why" is, his 4 cylinder engine and the mods he made would destroy your V8 64 tempest on the street if the two of you had a street race. We are not talking a couple of cars we are talking bus lengths difference in "The Gap".
Plus Charlie like to be different. His engine has a race turbo and fuel injection on it.
The picture he posted is a carbed 4 cylinder Pontiac engine.
Old 05-29-2020, 10:31 AM
I don't think so. Sorry. I think your car is great. Billk
Old 05-29-2020, 11:34 AM
Sirrotica's Avatar
https://www.ebay.com/itm/UNIVERSAL-T...0AAOSw8zNeplrQ
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
