Voodoo 703 or 702?
Finally getting my 389/400ci back from the machine shop next week, but second guessing my cam choise now. I have a the Voodoo 703 (227/233@050, 110LSA) but after reading the post by another member here who made 400hp/450lb-ft with the smaller 702 cam (219/227@050, 112LSA) in almost identical engine I regret not going with the smaller cam. The car is a 60 Bonneville with 4-speed hydramatic and 3.08gears. The engine is the original 389 bored 058 over, Icon pistons with 11cc dish, Eagle rods, stock crank, balanced, ported #76 heads from a 65 389, 1.5 roller rockers, Crower 68404 valve springs, Edelbrock RPM intake and a Holley 750. SCR is 10:1. The stock log mainfolds are port matched, cleaned up inside and the outlets opened to 2.2" with Pypes 2.5" downpipes to 2.5" Cherry Bombs Vortex mufflers. Should I bite the bullet and order the 702 cam instead?
1960 Bonneville 2dr HT 389/400ci 363hp 1965 Bonneville 2dr HT 455/501ci stroker 600hp+ |
If your not going to run Rhoads veri lifters with that 703 Cam then with your cid, the cars weight and rear gears then I would for sure step down to the smaller Cam .
I think you'll be fine with 10 to 1 compression and a 4 speed application. Should be pretty "rowdy" and work well with the manual transmission as idle quality is less important and you aren't up against a converter that might be a bit too tight.
We've used the Crower 60243 cam which is 228/235/112 LSA in similar engines with great success. It requires 10 to 1 compression for best results, but idles well and good street manners in 400 engine builds.......Cliff
He’s got an auto trans. I would step down. Maybe you can swap em out so you don’t have to buy another cam?
I live in Sweden so that can be a problem sending the cam back, but I can probably sell the cam/lifters here to make up for some of the loss. If I order the Voodoo 702LK kit from Summit it will cost me around 380$ with shipping, tax and toll. But if that cam is better suited for the car/engine combo I will order one today.
I personally wouldn't be afraid of it, and the larger cam will be less prone to detonation all else being equal......Cliff
Stay your course; that larger cam promotes ping-free pull-away.
my 455+ 060 runs the Street ping-free on 87 Octane, per cam below. |
Evaulate what the pressure will be with the Crower 68404 valve springs at your VERIFIED installed height. With that in mind take notice that based upon his dyno testing and extensive use of Voodoo cams Paul Carter recommends 130-135 lbs seat pressure with 30 degree seats and 330-340 lbs open pressure with the Voodoo hyd flat tappet lobes. Also he suggests to keep the distance from coil bind around 0.100". That and if you look at a Lunati catalog I believe you will find their recommended 73949 spring rated 120 at 1.650". Also keep in mind valvesprings will lose pressure after run in.
FWIW, if you a trying to run higher compression and your running a 702, but having problems driving it around on pump gas the 703 will not be much better. The 703 only has a slightly higher power band with a more power. Not really great ingredients for running extra compression.
The 703 was a great choice but it does not to need or want 10 scr compression, 9.5 would have been a lot better with either the 262/268 or the 268/276. I were in your shoes I would be unstrouding the valves and trying to drop the compression down to run the cam you have. |
I used it in a 69' T/A RAIII build & idled great and made 380 hp . Nice cam choice!
Carburetor building & modification services Servicing the Pontiac community over 20 years |
What's the quality of gas in Sweden? Would there be a seat of the pants difference in the cams with that heavy car? Wouldn't a Performer intake be a better choice? Is this car pretty much a cruiser?
Sounds good! If the SCR was 9.5:1 SCR or lower I'm sure the 702 would be the better choice but with 10:1 the DCR might be to high.
We have gas equivalent to US 93-94 octane here. I don't know which of the cams that makes the most power between 1500-5000 but i'm guessing the 702. The high 10:1 SCR made me choose the 703 instead. I already had the RPM intake for free so that was a easy choice. It's mostly a cruiser but I like to drive my cars quite hard.
I just looked at the cam card for the 703 cam and the adv. duration is 275/281, not 268/276?
The Following User Says Thank You to Burningbird For This Useful Post: | ||
https://www.lunatipower.com/voodoo-h...8-276-284.html You may have the 704.
+.050 locks will increase installed height.
