Old 05-26-2020, 07:24 PM
Tim Corcoran's Avatar
Default Degreeing a Cam Tool
Does anyone know a source for the crank adapter for attaching the degree wheel and for turning the engine? The one I have I bought from Powerhouse Products several years ago and it's a POS too loose on the crank and the slot for the crank key is loose also. Does anyone make one that's worth a dime?
Tim Corcoran
Old 05-26-2020, 08:30 PM
Tom Vaught's Avatar
Boost Engineer
I have had mine about 15 years (same Powerhouse deal) and works like a charm and is tight. Quality must have really dropped the last few years.
You could always machine the Powerhouse wheel hole larger, mount the wheel on a crank hub, machine slots in the plate for adjustment using the damper hub an pulley holes, and then use a normal crank bolt.
I know of no other large degree wheels out there but have not been looking either.
Tom V.
Old 05-26-2020, 08:37 PM
Formulajones's Avatar
I have a couple of modified degree wheels that I use and do pretty much what Tom mentioned. I mount mine on the snout using the crank bolt and washer.
https://youtu.be/XqEydRRRwqE
Old 05-26-2020, 10:00 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
I’ve got the comp cams crank socket tool. Works well for me
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 05-26-2020, 11:06 PM
grivera's Avatar
grivera grivera is offline
I also have the Powerhouse Products crank-nut it and it works great.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I use the moroso one and actually have had it turn with it bolted to the crank with crank bolt and washers.
So i decided to use a crank pully as a template and opened up the center and drilled holes so now it now bolts to the balancer. I think it works alot better this way. It still gets tightened down with the crankbolt but can just use a socket and breaker bar or 1/2" ratchet.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 05-26-2020, 11:43 PM
ANDYA ANDYA is offline
I also have the one from powerhouse products and the keyway is slightly loose. If your not paying attention you might not notice but it is loose. What I did was to put a plastic bag over the crank before I slid on the powerhouse adapter . The bag took up the space and the adapter went on tight. I've been thinking about using a crank timing chain sprocket with the teeth ground off to mount my degree wheel. A used lower gear will fit on the crank nice and tight, it's just a matter of figuring out how to hold the degree wheel onto it.
Old 05-27-2020, 09:16 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I think the Comp and Powerhouse are the same. I agree the keyway slot is a hair loose on both. I had a machinist (who I bought a Bonneville form for my first 455) cut a tighter one. It will even slip into the timing cover with seal if you want to check things with an assembled motor.
Skip Fix
Old 05-27-2020, 11:05 AM
So the answer is no one makes the tool for a Pontiac that is worth a sh*t and if I want a quality tool I have to make one. Thanks for the replies.
Tim Corcoran
Old 05-27-2020, 11:18 AM
77 TRASHCAN's Avatar
Seems like I remember that Butler used to sell a setup for a Pontiac...
Shut it off
Shut it off
Old 05-27-2020, 11:29 AM
Nothing that a proper size drill bit won't fix. 10 seconds and done.
Old 05-27-2020, 03:20 PM
Region Warrior's Avatar
Sounds similar to what I did.
Have old balancer drilled and tapped to mount wheel to.
Then just bolt assembly to crank.
Old 05-28-2020, 09:35 AM
Skip Fix's Avatar
Tin the Comp/Powerhouse is a pretty good tool, and you can shim the slot easily. It also has an allen bolt to lock it in place on the crank. Good enough I bought a spare.
Skip Fix
Old 05-28-2020, 03:02 PM
JC455 JC455 is offline
I use the Comp one with (2) set screws/slots on it. It fits on and snugs right up.
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 06-03-2020, 10:13 PM
I gave up trying to find one so I made one. I got a crank timing gear cut off the teeth on a lathe then welded it to the sloppy Powerhouse Products tool. Now it works like it's supposed to nice and tight and the key way fits nice too with no slop or back and forth movement and no marks on my crank from set screws. Since I don't have a lathe and don't have a welder I had this done for me but the guy is a real cool dude and did the job for $40 I really lucked out.
Tim Corcoran
Old 06-04-2020, 08:13 AM
Tom Vaught's Avatar
Boost Engineer
One my best day I could not weld like a couple of fabricators I use.
Nothing wrong with going to a Pro even if you have the equipment
Most would not turn their machine on for $40, you did well.
Tom V.
