Old 09-17-2019, 04:17 PM
mgarblik mgarblik is offline
45 + years working with Pontiac engines. Was pretty sure I had seen everything. Wrong again! I love it. Went to considerable effort and ruined two perfectly good quarters to perform that repair.
  #42
Old 11-14-2019, 09:55 PM
74SDformula's Avatar
74SDformula 74SDformula is offline
I think this will work a little better. Or at least it looks better.
ID:	524517   Click image for larger version
  #43
Old 11-14-2019, 10:14 PM
242177P's Avatar
242177P 242177P is offline
And it isn't pink!!
  #44
Old 11-15-2019, 11:20 AM
dataway's Avatar
dataway dataway is offline
It will certainly work better ... but I think it lacks character
  #45
Old 11-15-2019, 11:23 AM
Sirrotica's Avatar
What did you do with the 2 quarters?...…………
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #46
Old 11-15-2019, 12:25 PM
Keith Seymore's Avatar
Originally Posted by NeighborsComplaint View Post
Definitely not a nickel and dime build.
This comment did not get enough recognition.
K
'63 LeMans Convertible
'63 Grand Prix
The Following User Says Thank You to Keith Seymore For This Useful Post:
  #47
Old 11-15-2019, 08:13 PM
mchell's Avatar
mchell mchell is offline
What were the dates on the quarters???...couldn’t make it out in the pics...
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #48
Old 11-15-2019, 09:55 PM
242177P's Avatar
The one on the RH side (left when viewed from the front) was 1991.
  #49
Old 11-15-2019, 10:17 PM
mchell's Avatar
Cracks me up.... that dude was getting some bang for less than a buck....bwaaaaaaaaaahhhhaaaaaaaaa
  #50
Old 11-16-2019, 06:06 AM
dataway's Avatar
Well .... all I have is the standard pressed in plugs .... so the quarters might be an improvement over that.
  #51
Old 11-16-2019, 05:56 PM
Dragncar Dragncar is offline
I have had the standard pressed plugs for years. But what I did was take a square edged file and make some little cuts in the plug and take the handle of the file and make a few deep scratches in the block where the plug fits. I did this so the JB Weld would have more to "grab" that i smeared on the plug. Like where you sand something when you epoxy it.
Then I staked it on the inside lip with a punch then filled the rest with JB.
Its not coming out.
You can still tap it for pipe threads at a later dare if you chose.
  #52
Old 11-16-2019, 10:34 PM
Maybe he used them to buy 2 screw-in plugs.
  #53
Old 11-17-2019, 07:22 AM
That must be the safety mod for the 60 psi pump as I hear the the 80 psi pump needs two of the thicker silver Dallor coins to be used there!
