Old 02-15-2020, 04:10 PM
GTM GTM is offline
Send a message via Yahoo to GTM
Default 66 Sprint cylinder head question
Anyone know what the camshaft oil feed hole size is supposed to be changed to?
Old 02-15-2020, 05:07 PM
Jeff Hamlin's Avatar
Thumbs up '66 Oil Metering Tube...
Old 02-15-2020, 05:21 PM
GTM GTM is offline
wow, that's a lot smaller than what mine is now. where do you get that sleeve, do you know? Thanks
Old 02-16-2020, 09:04 AM
You can repair yours per outline above, or buy one from Woodland Sports. (Jerry)
Old 02-19-2020, 06:35 PM
GTM GTM is offline
I read you can tap the hole, install a set screw, then drill it out
Old 02-19-2020, 07:17 PM
I've never heard that and it doesn't sound like a good way to correct the metering hole deficiency.
I think If a screw is used it seems it would then make re-drilling the "oil channel" back to correct size harder.
Also, I would be concerned the screw could dislodge then you would have big problems.
If welded/brazed then a new/correct size metering hole can be easily relocated alongside the filled hole,
then it's just a matter of redrilling the "oil channel".
Old 02-20-2020, 09:21 AM
Hokie1984 Hokie1984 is offline
They cost like $20. If they were $200 then I could see attempting some type of repair, however, I would never rely on something screwed in.
Old 03-12-2021, 02:09 AM
PepinoBBB PepinoBBB is offline
i believe in other forum they have instructions. Just type OHC
