OHC-6 TECH Over Head Cam projects, questions and advice.
Old 02-02-2020, 02:29 AM
exotec exotec is offline
Default Motor mount parts help, please
I'm swapping an ohc6 in my x-body Olds Omega, which uses the 1st gen f-body subframe.
https://forums.maxperformanceinc.com...d.php?t=837283
now I'm struggling with finding the correct motor mount parts. Would need insulator and frame bracket.
The picture in the Pontiac Service Manual does show for the 6 Cyl engine the Tempest, I think.
So I'm lost a bit and appreciate any help!
Is this a correct f-body motor mount for an ohc6 engine?
https://www.ebay.at/itm/Pontiac-Fire...s/303133113084
Any other source or used parts from forum members are highly welcome!
serwas
Karl
follow my project on instagram
Old 02-02-2020, 07:08 AM
Jeff Hamlin's Avatar
There are two types of mounts and brackets for our OHC's.
Tempest and Firebird.
The Tempest mounts use a long connecting through bolt to secure the mount to the frame bracket while the Firebird mounts have a center bolt provision in the mount and the primary frame brackets are a taller "stand" type design with supporting brackets.
The first 2 images below are Tempest parts and the last are Firebird.
Cheers.
Old 02-02-2020, 04:26 PM
Thank you Jeff.
What I assumed you confirmed, that my service manual just shows the Tempest version!
Someone hast a set of this parts left for me, please?
Shipping to Austria or Humble, TX will be required.
Thank you all.
serwas
Karl
Old 02-02-2020, 06:18 PM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Try placing a wanted ad in the "67-81 Firebird & TA Parts WANTED" further down the forum list.
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 02-03-2020, 01:17 AM
very good advice! done
Thank you
serwas
Karl
Old 02-10-2020, 10:23 PM
Rick Rick is offline
If you still need the Firebird Frame mounts I have a set on Ebay:
eBay item number: 202901011424
Rick
Old 02-10-2020, 11:10 PM
👍 yes sir!
serwas
Karl
Old 02-16-2020, 05:37 AM
Rick
Hi Rick,
Thank you for the ebay number! I was successful.
Kind regards
Karl
serwas
Karl
