OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-26-2020, 03:37 PM
63 bomb's Avatar
63 bomb 63 bomb is offline
Default Missing Bolts
Hello all, I am looking for two missing bolts for my '67 Sprint. They are the two front valve cover bolts that also hold the upper timing belt shield on. Thank you in advance.
Old 03-26-2020, 07:14 PM
Jeff Hamlin's Avatar
You're looking for Double Ended Studs here are the specs.
These are also on the rear/back of the cover.
Also used as a guide for cam house installation.
If you can't find them local LMK I'm sure I have some.
Old 03-27-2020, 09:36 AM
63 bomb's Avatar
Great info, thank you! I'll look around locally to see what I can find. If I can't find them I'll be sure to let you know. Thanks again.
Old 03-29-2020, 05:31 PM
Thumbs up Found a set...
Pulled the bins and do have a good set.
Old 03-30-2020, 08:27 AM
Hokie1984 Hokie1984 is offline
I had an issue where one of the bolts was not inserting all the way and I didn't seal that end of the cam gasket. Bottom line, chase the threads (both sides) before installing. Forced me to pull the cover. All fixed now, but PITA.
