Old 05-15-2020, 06:32 PM
Tomaso Tomaso is offline
Default Flasher on fuse box? 66 Pontiac Bonneville
Hi Guys,
Does anyone have a picture of there fusebox for a 66 full size?
My Bonnevilles looks like this. is there suppose to be a flasher in that corner?
It doesnt look like theres metal prongs in mine or its missing?
Mike
Old 05-20-2020, 12:44 PM
killakev's Avatar
killakev killakev is offline
Yes a flasher goes in there. You should have prongs in there also. Remove it from the firewall and separate the front face from the back and see what is there.
Old 05-20-2020, 12:46 PM
What's wierd is there is a flasher that fits it. However it wont fit because of that bolt and there are no prongs.
Mike
Old 05-20-2020, 01:20 PM
george kujanski's Avatar
The flasher on the fuse box is typically the hazard flasher...at least on a "A" body. If that's true with yours, didn't the hazard flashers start being supplied in '67?
George
Old 05-20-2020, 09:17 PM
stevep's Avatar
stevep stevep is offline
George
Yes, Hazard flashers were an accessory up to 1966
Old 05-25-2020, 03:39 PM
mgarblik mgarblik is offline
The flasher for the turn signals is in the wiring harness and clips to the dash face roughly in the area of the radio/ash tray
Old 05-25-2020, 04:10 PM
MISTAKE IN ABOVE POST! Verified in chassis manual. Flasher is next to instrument cluster , roughly parallel to it in a clip on the left end of the cluster area. NOT near the radio/ash tray. Sorry, wrong year. Pink power wire from fuse box feeds connector. Purple wire from the turn signal switch completes the circuit.
Old 10-20-2023, 10:20 PM
kpbrown31 kpbrown31 is online now
Originally Posted by Tomaso View Post
Hi Guys,
You don't happen to have a picture of the backside of your fuse box do you? My 66 had a very rust one and several wires were pulled off the back. I'm down to a few brown wires (I think headlights?) that I'd like to confirm where they go. I'm in the middle of putting my Painless wiring fuse block in and just trying to compare a color picture with the diagrams in the manual. Thanks
