Old 06-05-2020, 04:39 PM
footjoy's Avatar
footjoy footjoy is offline
Default 65 Tempest V8 Looking for starter wiring tips
I was wondering if anybody had any ideas on wiring a starter other than dropping the starter and disconnecting wires.
maybe solenoid or junction block just looking for a better idea.
Greg
Old 06-06-2020, 02:54 AM
Chris65LeMans's Avatar
What’s the problem you are having with the starter? I didn’t think dropping it was too difficult.
Old 06-06-2020, 06:03 PM
You can use a two piece positive battery cable like a 1964 big car. also make your own 2 piece purple solenoid wire. That way you can leave the wires connected to the starter and disconnect them up at the fender.
Old 06-06-2020, 10:18 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Used a relay at the junction point, were the 2 cables meet. But only used the relay for purple start wire, instead of having the ignition have major amperage go thru it, I put a 40 amp relay and used the ignition switch to control the relay. Had a new ignition start to go funny before i did this, all good now, has been 5 years with no issues.
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 06-07-2020, 09:48 AM
LATECH's Avatar
LATECH LATECH is offline
64 lemans has a very excellent Idea with the relay.It can save your ignition switch
Old 06-10-2020, 09:30 PM
Lemans64's Avatar
Pictures of relay.
ID:	542196   Click image for larger version
ID:	542197   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 06-10-2020, 09:31 PM
Lemans64's Avatar
Black is start wire from ignition switch
Red is power from battery
white is relay ground
blue is start wire going to starter.
64 Lemans hardtop
4spd, buckets
Old 06-10-2020, 09:55 PM
footjoy's Avatar
Thank you very much
Greg
