Old 10-23-2023, 04:35 PM
Hank Hank is offline
Default 66 center carb
Does anyone have any leads on a 66 center carb? Stock motor.
Old 10-24-2023, 10:08 AM
dhcarguy's Avatar
dhcarguy dhcarguy is online now
Have you tried Mike Wasson @ pontiactripower.com or, Dick Boneske 920-450-1040
Old 10-25-2023, 12:24 AM
Dick Boneske's Avatar
I have a correct '66 center carb. This is the hardest Tri-Power carb to find. DM me if you are interested.
If for a stock engine, stock cam, I will supply unmodified. If you have an aftermarket cam, let me know before I ship, so I can calibrate accordingly.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 10-25-2023, 12:25 AM
BONESTOCK GOATS
Old 10-26-2023, 05:34 PM
I also have a clone '66 center carb. Functionally and cosmetically, compatible with the "correct 575" center carb. Price will be much lower than a "correct" carb.
BONESTOCK GOATS
Old 10-26-2023, 11:27 PM
mike w mike w is offline
I can supply one, also. Feel free to call me at (309) 360-6385
Old 10-28-2023, 02:47 PM
61-63's Avatar
61-63 61-63 is offline
Mike you need to post on here more it's good to know you are still around and Kicking.
Old 10-28-2023, 02:56 PM
Thanks. I still keep busy restoring and building Pontiac units. I have a very correct 65 unit ready to go, if anyone is interested. It is in the correct factory color.
