Old 11-29-2023, 12:37 AM
wbnapier wbnapier is offline
Default '65 Tri-Power Idle's Rich When Cold
Hello,
Recently restored '65 Tri-Power has begun running rich, 10-11:1 AFR at idle when cold. Sounds and idles horrible and can stall out unless I feather the throttle.
After warming up and driving 3-4 miles the issue self-corrects and the idle AFR is 14-15:1 and the idle is smooth and good.
I have a center carb rebuild kit and I am thinking of simply doing a basic rebuild and doing my best to clean the idle circuit.
Any ideas on what causes a rich idle when cold, but self corrects when warm after a few miles?
Thanks!
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 11-29-2023, 04:22 AM
Kenth's Avatar
Kenth Kenth is offline
Choke settings?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-29-2023, 12:21 PM
dhcarguy's Avatar
dhcarguy dhcarguy is online now
Agree, choke setting
Old 11-29-2023, 12:51 PM
Choke operates normally, I have confirmed the choke plate is open.
Maybe the float is sticky and frees up after some heat and driving around?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 11-29-2023, 11:00 PM
What is normal?
Manifold heat to cross-over?
Heat tubes to choke working properly?
Correct choke spring for the Tri-Power?
TV
Old 11-29-2023, 11:10 PM
Choke, fast idle, etc. all set up and functioning properly. The vehicle cold starts fine, fast idle bumps it up to 1500 rpm, and choke opens with heat, etc... The carbs where restored by Mike W., so are set up as correct as can be in our hobby. Idle mixture tubes have been enlarged by Mike in accordance with my engine specs.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 11-30-2023, 07:04 AM
Kenth's Avatar
Vacuum leak?
Flooding condition/black exhaust?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-30-2023, 01:04 PM
No, vacuum leak would result in a lean condition. I have an O2 gauge. This is a rich condition. It's not flooding either.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 11-30-2023, 04:06 PM
Kenth's Avatar
Ok, then i would check the choke rod adjustment.
For 1965 Tripower the measurement should be .055".
If this still makes a too rich initial cold start mixture you may want to adjust to a slightly larger distance.
HTH
Name:	2GC Choke Rod Adjustment.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-30-2023, 05:18 PM
OK, but the condition persists when the choke is fully open (visually confirmed), then self corrects when fully warmed up, 180F, and I have driven 3-5 miles.
I'm going to clean out the idle circuit as best as I can and take it from there.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 11-30-2023, 10:56 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Have you spoken to Mike to review your engine/trans specs and his choice to increase idle tubes? What did he say? While end carb problems usually result in lean idle conditions, have you removed end carbs and installed blanks?
Old 12-01-2023, 09:46 PM
65 Lamnas's Avatar
Mike's been doing Tripowers for a very long time. I'm sure if you call him, he'll walk you right through the steps and what to look at, or if he needs a carb back from you. He's a nice guy and very approachable....If it were me, I'd give him a text and a ring.
Old 12-11-2023, 07:18 PM
I did a full rebuild today.
The one issue I found was a damaged / torn accelerator pump rubber cup. See photo.
Car runs great now!
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 12-11-2023, 07:44 PM
Problem solved
It did a complete rebuild and found a torn accelerator pump rubber cup
See photo
Car runs great now. Click image for larger version
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 12-11-2023, 07:45 PM
Problem solved
See photo
Car runs great now.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 12-11-2023, 09:25 PM
GtoFM's Avatar
Ahhh! the simple things in life...that can drive a man to drinkin'!!!
Happy you found the culprit.
Old 12-14-2023, 02:00 PM
Dick Boneske's Avatar
Sorry, I don't understand how the torn pump cup could cause flooding.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 12-14-2023, 03:59 PM
65 Lamnas's Avatar
"Flooding" was never the issue.
Old 12-14-2023, 05:13 PM
Kenth's Avatar
I can't see how a torn pump cup causes a rich idle when cold, but self corrects when warm after a few miles?
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
