Tri-Power Tech 57-66 Tri-Power Talk
Old 07-30-2023, 10:11 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default 65 float levels and drops
What should these measurements be to keep the fuel in the bowl lower than the airhorn gasket while driving on fairly level highways. For the center carb, stock says float level at .023 but the kits says .021.
The ends at.023
Float drops at 1 3/4"
Thanks, Dave
Old 07-30-2023, 03:08 PM
Kenth's Avatar
Kenth Kenth is offline
Delco Bulletin 9-PO-1 1965:
Center to be set at 11/16" from toe of float at sharp edge of seam to air horn gasket and 1 3/4" drop from gasket surface to bottom of float.
End carbs 21/32" and 1 3/4" drop.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
