Tri-Power Tech 57-66 Tri-Power Talk
Old 02-15-2024, 01:27 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default air horn # 7024855
I have what looks to be a correct air horn for a 65 center carb. However ,the number on the back side is 7024855.
Can someone tell me what this is from?
Thanks, Dave
Old 02-16-2024, 09:15 AM
dhcarguy's Avatar
Anyone?
Old 02-16-2024, 09:32 AM
Kenth's Avatar
Kenth Kenth is offline
Pictures?
1957-58 Pontiac center carbs are using the 7008594 air horn,
1959-60 Pontiac center carbs are using the 7012710 air horn.
1961-65 Pontiac center carbs are using the 7017917 air horn.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-16-2024, 12:50 PM
dhcarguy's Avatar
The carb with brass fuel fitting is correct.
Don't know why the pictures are sideways.
ID:	628696   Click image for larger version
ID:	628697   Click image for larger version
ID:	628698   Click image for larger version
Old 02-16-2024, 01:21 PM
dhcarguy's Avatar
trying
Old 02-16-2024, 05:58 PM
Dick Boneske's Avatar
Only the '61-''65 had the 1/4" pipe at the top of the airhorn to connect to the choke heater tube. The ones ;you show in the pictures appear identical to the correct '65 airhorn.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-16-2024, 08:22 PM
dhcarguy's Avatar
Thanks Dick
I know they appear the same, but just one has the correct #7017917.
for a 65 air horn.
The other looks very similar, but has #7024855 on the under side. I don't know what year it is for. (maybe for a full size car????)
Thanks, Dave
Old 02-17-2024, 11:07 AM
Here you go
ID:	628767   Click image for larger version
ID:	628768   Click image for larger version
ID:	628769   Click image for larger version
Old 02-17-2024, 11:36 AM
carbking's Avatar
carbking carbking is offline
I don't have one apart to check the casting number, but that airhorn looks like one from the 1959/60 389 "E" carb.
These carburetors, with a small increase in the idle jet, and or course different main jetting, work well for the individual wanting tripower, but not wanting to spend the funds for numbers matching.
Have sold a lot of them over the decades.
Jon
Old 02-17-2024, 11:38 AM
dhcarguy's Avatar
Thanks Judge
Old 02-18-2024, 10:02 AM
dhcarguy's Avatar
Thanks Jon
