Old 02-23-2024, 04:26 PM
Tim Corcoran's Avatar
Default Old vs New Edelbrock Heads
With regards to round port e-heads, does anyone have any race track or dyno data on the difference between the older style combustion chambers and the new fast burn style? Is it worth to have them converted to the new style?
Tim Corcoran
Old 02-23-2024, 05:08 PM
Steve C. Steve C. is offline
Heart Shape Combustion Chamber Dyno Test
https://www.sdperformance.com/newsStory.php?newsID=41
https://www.sdperformance.com/newsStory.php?newsID=38
Old information here:
Old 02-23-2024, 05:42 PM
Chamber Chatter
No testing data here, but some might have interest in the Edelbrock development of their heart-shaped combustion chamber for the Pontiac cylinder head.
https://www.motortrend.com/how-to/in...ead-edelbrock/
Old 02-23-2024, 05:57 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Each chamber has its place.... You can go far wrong with the CNC chamber. In our few "back to back" tests we haven't noticed much difference other than tuning requirements.
Go fast, see Elvis!
Old 02-23-2024, 06:43 PM
steve25 steve25 is offline
In theory motors with high piston speed should benefit from a fast burn chambers, and of course high reving motors like above 6500.
Old 02-23-2024, 08:34 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
i think for boost the old style is better....when i had mine opened up from dave at sdperf i asked for the heart shape chambers but since i had told him it was for a blower motor he advised against the faat burn chambers
Old 02-23-2024, 10:18 PM
ponjohn's Avatar
ponjohn ponjohn is online now
How so?
Old 02-24-2024, 09:36 AM
PAUL K's Avatar
The CNC chamber is more sensitive to cam timing, piston design and burn rate.... But it's a good chamber and glad we have a choice.
Go fast, see Elvis!
Old 02-24-2024, 10:22 AM
78w72 78w72 is offline
Who does the conversion of older chambers to the newer hear shaped? I asked SD (before the fire) about doing that to a set of my 72cc E heads and he said they dont offer the service anymore since edelbrock sells them that way now.
Old 02-24-2024, 10:46 AM
chuckies76ta's Avatar
Is it not also an issue with the new HSC if you want higher flow numbers,(cfm's) you need the old Edelbrock heads?
Old 02-24-2024, 11:17 AM
PAUL K's Avatar
Flow wise the CNC chambers have an advantage.
Go fast, see Elvis!
Old 02-24-2024, 11:33 AM
PAUL K's Avatar
We designed a program around 2000. It was originally created for one of Butler's "Engine Master" entries. Unfortunately with today's labor costs and inflated parts prices it wouldn't be cost prohibitive to convert a set.
Go fast, see Elvis!
Old 02-24-2024, 12:36 PM
Thanks Paul. You got me thinking. I wonder what kind of timing the old chamber E- heads use. I thought the old chambers were using around 36-38* timing.
With our 505 we were at 34* on the dyno. 91 octane. We ran C12 at the start to find our best timing.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 02-24-2024, 09:31 PM
AG's Avatar
AG AG is offline
My old bathtub Eddy chambers work best at 39 degrees timing for best mph.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following User Says Thank You to AG For This Useful Post:
Old 02-25-2024, 11:03 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My two "old" chambers one likes 38 the other 40.
Skip Fix
Old 02-26-2024, 10:12 PM
Thanks for all the replies, it sounds like there is no reason to bother with changing anything. If I was class racing and chasing every last pony then I would say it would be worth it. For my mild bracket motor not worth it.
Tim Corcoran
Old 02-28-2024, 09:47 AM
grandville455's Avatar
grandville455 grandville455 is offline
How much power or et do u lose with say 35 degrees?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 02-28-2024, 09:49 AM
Hi Darby: What heads are you running now? Or are you still running the KRE D-ports? Thanks
Old 02-28-2024, 10:12 AM
Skip Fix's Avatar
Not a lot maybe 4-5hp.
Skip Fix
Old 02-28-2024, 10:22 AM
Yea, So not even worth running it that high then really if no major gains
Darby
