Old 05-08-2016, 09:47 PM
archerytony's Avatar
archerytony archerytony is offline
Default Rear frame rails trans am
Anyone here replaced rear frame rails on a 77/78 firebird? If so we're did you find them or why don't any of the other years work?
www.bowhanger.com
468 poncho powered 66 cutlass
77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html
Old 05-09-2016, 11:06 PM
Cool
Boy you guys ain't much help!
www.bowhanger.com
Old 05-21-2016, 10:53 PM
Formulabruce's Avatar
The later 2nd gen Birds have a lower CG, which improved handling and the actual rear frame rail reflects this. I have replaced them in 2, 78 T/A. One I flanged and replaced most of the hump and back, the other car, did it all . Both time on its side, one was from a tractor, next was a rotary made for it. Get extra spot weld removed bits...
Old 05-21-2016, 11:02 PM
MD79TA MD79TA is offline
This is hit man address http://www.78ta.com/index.php this is another real good site for trans am info http://transamcountry.com/site/tac-mobile please let us know how thing go. If you have any picture of rust post and we can help a lot more based off them . Also post in the 77-81 trans am / fire bird tech section you might get more feed back . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 05-21-2016, 11:27 PM
I looked and didn't see anything on rear frame rails?
www.bowhanger.com
Old 05-21-2016, 11:41 PM
Sorry but you got to do a better job at search . Tons of info out there on frame rails Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-22-2016, 08:26 PM
I m sure you have been told this but it is by no way a easy job. I would strongly suggest having it done . You real need to know what you are doing and having a jig to keep straight sure would help. But I have read of some doing them even bolted to body but just can't see that being a positive outcome. Still waiting to see some pictures maybe not that bad. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-23-2016, 11:50 AM
Thanks for the advice Doug but I have no problem doing it myself I was just seeing if there was any after market ones out there that would work other wise I will just make them
www.bowhanger.com
Old 05-23-2016, 12:23 PM
Most I have seen done use the rails from a donor car.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-23-2016, 01:05 PM
You must need the front sections ?
The rear 3/4 sections are readily available
LH = FK371T
RH = FK371V
From our Host Ames performance.
Old 05-23-2016, 07:45 PM
YESSIR!
www.bowhanger.com
Old 05-23-2016, 10:00 PM
I'm lost on this thread.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-23-2016, 10:08 PM
I asked because I could only find 79 and later complete rails and up to 76 but none for the 77 and 78 and was wondering what's the diff in them
www.bowhanger.com
Old 05-23-2016, 10:18 PM
Lost on what you need? Front or rear? If front just buy from junk yard and bolt them on. If rear again junk yard or buy new many venders don't think there is any difference on those years but Ames has a great tech department just call . That should take care of you . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-23-2016, 11:12 PM
I don't think there was any changes on these rails over the years. Im not and expert. Would think if any they would be minor. I m sure our friends at Ames could take care of you.
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 05-24-2016, 01:16 PM
[QUOTE=Formulabruce;5578840]The later 2nd gen Birds have a lower CG, which improved handling and the actual rear frame rail reflects this. I have replaced them in 2, 78 T/A. One I flanged and replaced most of the hump and back, the other car, did it all . Both time on its side, one was from a tractor, next was a rotary made for it. Get extra spot weld removed bits...[/QUO Bruce I talked to Ames and it looks like the complete early ones are the same fit 70 to 73 but dont have some of the hardware mounting holes I think from the pictures they sent me that it wouldnt be to hard to make them work.
www.bowhanger.com
Old 05-24-2016, 03:48 PM
The car body was lowered on the frame in later years as the gas tank was put up into the trunk. The 70-73 dont have the later sway bar holes or reinforcements in the top of the arch. If Ames says the rest is the same, adding in that reinforcement and holes wouldnt be that big a deal. I dont have any out side by side to compare . Good luck !
Old 05-25-2016, 06:08 PM
The guy I talked to sent me some pics of the complete 73 rail and the 3/4 77 rear rail and they looked the same as far as the bends go up to were the front part of the 3/4 is
www.bowhanger.com
