Old 06-22-2003, 07:41 PM
80TA 80TA is offline
I have subframe connectors to put in and likely will be putting in a eight point rollbar to be track legal
for planned engine.Are those braces that go from fender to rad support necessary or do they actually do anything??Do most guys leave them in or take them out.
80TA,pontiac 400,edelbrock carb,accel wires,dual exhaust,dynomax mufflers,no cats,3.42 gears.CE subframe connectors to be installed.On order B&M quicksilver,Polygraphite bodymounts.
15.1 at 96mph 2.47 60ft uncorrected tazzo vpc.
99TAWS6 ..lots of mods.13.35 at
109 2.27 60ft uncorrected tazzo vpc.
1900 ft altitude.
80TAWS6,400,edelbrock 750 carb/performer rpm intake/crane cam and lifters,/magnum 1.52 rocker arms/comp pushrods/arp rocker studs,cloyes double roller,crower valve springs,ias shocks,msdl wires,dual exhaust,flo pro mufflers mufflers,turbo 400, 2400 nitrous holeshot,3.42 strange gears.
1900 ft altitude.
Old 06-22-2003, 08:31 PM
Actually they act kind of like a monty- carlo bar in the mustangs, they help tie the frount end together. But just like the old stock mustang bars they are flimsy.I believe Larry Nivaro has some nice Bar stock units made up for sale for about 30 bucks, i know they look really cool, and they are alot thicker to help reduce flex.
Mike
Old 06-22-2003, 09:13 PM
Young One79TA Young One79TA is offline
Here's a link to Larry's custom braces.
I'll probably buy some as soon as I get my car back together.
http://forums.performanceyears.com/g...1&m=2526054813
Old 06-22-2003, 10:24 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Those bars do add structural rigidity but are not an important part of the car. '70-'72 Firebirds didn't even have them. They were added in 1973 to meet the stricter crash standards imposed that year.
1971 Trans Am 455 HO - Cameo white
1973 Trans Am 455 - Buccaneer red
1984 Trans Am 305 - Royal blue
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 06-23-2003, 01:31 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Herb Adams old "front structure kit" had a brace that bolted from firewall/cowl lip and front fender bolt to the front upper A arm bolt. There were also some small braces on the lower A arm bolts to frames on TAs and Z28s. All tie into frame and not just the femder to core support.
Skip Fix
Old 06-23-2003, 01:56 PM
Skip,
Did you ever buy any of Herb's front structure kits?
Old 06-23-2003, 03:34 PM
Skip Fix's Avatar
I've got one for A/C and had it chromed.(It may go on this Camaro project getting my 455 in it) Got tired of trying to change #2,4 plugs with it. Tried the Herb Adams subframe bushing kit, rear sway bar(great with a stock front one for a looser rear end). And I have his solid bushing/spherical bearing weld in front A arm kit I am finally going to use in a Camaro after 20 + years.I never wanted to weld in my original A arms. I got alot of it when I lived in San Jose and would drive down to Monterrey to their shop.Fun drive down some of the back roads in my TA, wife stil says most of CA was a blur in the TA.
Skip Fix
