Old 10-16-2015, 04:37 PM
mechanickeith's Avatar
Originally Posted by JohnFromVentura View Post
It does.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #62
Old 10-17-2015, 08:30 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 1963-Tempest-Lemans-power-steering-4-cyl-mounting brackets
These 4 brackets came with a used power steering setup from a 4 cyl car, I needed brackets for my 326.
Not sure if these fit all 3 years?
http://www.ebay.com/itm/121790639215
Asking $49 for all 4, free shipping.
  #63
Old 10-20-2015, 02:07 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Default 63 LeMans Rt Tail light Assy
Bump!
  #64
Old 10-26-2015, 04:49 PM
indiantony indiantony is offline
Originally Posted by indiantony View Post
3 speed torque tube and shaft $50
Remote mirror $75
Brake and clutch pedals $150
Emergency brake pedal $20
Doors from a 4 door $40 each
Sun visors $5
Original radio delete plate $200
Rims $20
Emergency brake cable $25
Speedometer cable $25
Fender extensions $25
Quarter panel extensions $25
Lemans gas door $20
Tempest tail light lens $20
Hood hinges $20
4speed shifter rod $50
Hub caps $10 each
Bucket seats $300
Repro Dash shifter delete plate $35 unpolished $40 polished
Many more parts also
Prices Do Not include shipping
Tony
917-681-6534
bump
  #65
Old 10-28-2015, 06:17 PM
Default 63 Tempest "Frame"
If anyone is looking too repair any rotted "Frame" section this is whats left of a 63 that I parted out.
  #66
Old 11-06-2015, 12:53 AM
Sanduners's Avatar
Some parts I have now listed on Ebay. Some auctions, some buy it now.
1963 Pontiac Tempest / Lemans Drive Clutch Shaft and Bearing Support $49.99
http://www.ebay.com/itm/121803150450?item=121803150450
Original Inside Window Crank Handles 1963 Pontiac Tempest Lemans $15.99
http://www.ebay.com/itm/Original-Ins...908303?vxp=mtr
Original Inside Door Handles 1963 Pontiac Tempest Lemans $15.99
http://www.ebay.com/itm/Original-Ins...234446?vxp=mtr
1963 PONTIAC TEMPEST LEMANS HEADLIGHT BEZELS 545149 & 545150 LEFT & RIGHT $99.00
http://www.ebay.com/itm/1963-PONTIAC...908300?vxp=mtr
1963 Pontiac Tempest Lemans power steering 4 cyl mounting brackets $49.99
http://www.ebay.com/itm/121790639215...S:1123&vxp=mtr
1963 PONTIAC TEMPEST LEMANS SIDE FENDER SPEARS 548445 & 548446 LEFT & RIGHT $99.00
http://www.ebay.com/itm/1963-PONTIAC...908305?vxp=mtr
Original Pontiac Air Cleaner Support - 195cc 4cl $19.99
http://www.ebay.com/itm/Original-Pon...268206?vxp=mtr
1962 1963 PONTIAC LEMANS INTERIOR DOOR EMBLEMS $79.99
http://www.ebay.com/itm/1962-1963-PO...234445?vxp=mtr
And still have parts available from a 63 4 door parts car. Thanks
  #67
Old 11-20-2015, 03:41 PM
tiacguy's Avatar
tiacguy tiacguy is offline
Default 61-62 tempest wagon tailight lens NOS
NOS taillight lens. $15.00 shipped. Brand new never mounted in original box. However it does have some minor handling scratches from being in the box unwrapped.
  #68
Old 11-22-2015, 03:55 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default For Sale Pair of NOS lower Ball Joints
One pair of GM Ball joints in the box, fits all 1961-63 Tempest and Lemans.
$125 plus postage.
Name:	1961-63 Tempest NOS Lower Ball Joints_Th.jpg
ID:	413970   Click image for larger version
Name:	1961-63 Tempest NOS Lower Ball Joints_E1.jpg
ID:	413971   Click image for larger version
Name:	1961-63 Tempest NOS Lower Ball Joints_E3.jpg
Peter Serio
Owner, Precision Pontiac
  #69
Old 11-23-2015, 03:22 PM
cleveweld's Avatar
cleveweld cleveweld is offline
Default 61-63 Tempest Kent-Moore Tools
1961-63 Tempest Kent-Moore Automatic Transmission Bushing Installer Tools
These appear to be lightly used and are in excellent condition. These are shown in my 62 shop manual pgs 7A-40 & 41 and 4-30 & 31.
J-8360-3 Low sun gear bushing installer
J-8360-4 Rear pump body bushing installer
J-8884 Front pump body bushing installer
J-8886-1 Front turbine shaft bushing installer
J-8886-2 Rear turbine shaft bushing installer
J-8887 Bushing installer (Pinion shaft)
J-8888 Drive pinion rear bushing installer
J-9211 Clutch drum bushing installer
J-9229 Converter bushing installer
$55 for the set plus shipping
1961-63 Tempest Kent-Moore Differential Tools Shown on pgs 4-30 & 4-31 of 62 shop manual. These appear to be NOS with no signs of wear or use.
J-8362 Pinion turning adapter (for setting pinion bearing pre-load)
J-8897 Pinion bearing adjusting nut outer race remover
J-8901 Differential side bearing installer
J-8902 Side bearing adjusting nut wrench
J-8903 Side bearing pre-load & backlash checking fixture
J-8980 Speedometer gear installer
$75 for the 6 differential tools plus shipping
1961-62 Tempest Shown on 62 Tempest shop manual pg 3-24.
J-8347 Rear control arm bushing remover & installer $29 plus shipping
Name:	KM Auto Trans tools 010.jpg
ID:	414036   Click image for larger version
Name:	KM Differential tools 004.jpg
ID:	414043   Click image for larger version
  #70
Old 11-23-2015, 03:36 PM
cleveweld's Avatar
Default NOS 1961-63 Tempest & LeMans Differential Gear Set
This is a complete 1961-63 Tempest NOS differential gear set including thrust washers and pinion gear shaft. All parts in excellent condition.
539008 Gear, Differential Side
541340 Gear, Differential Pinion
539013 Pinion Gear Shaft
539200 Washer, Differential Side Pinion Thrust
539201 Washer, Differential Side Gear Thrust
$189 for the set plus shipping
ID:	414048   Click image for larger version
ID:	414049   Click image for larger version
  #71
Old 01-12-2016, 09:03 PM
Sanduners's Avatar
A couple items on Ebay. A decent Lemans gas door and a good Lemans left rear bezel.
http://www.ebay.com/itm/121859527653...84.m1555.l2649
http://www.ebay.com/itm/121859535676...84.m1555.l2649
ID:	418050   Click image for larger version
  #72
Old 01-21-2016, 08:56 PM
Default 12 Hole Tempest Hubcaps
Nice set of 5 63 (could be 62 also?) 12 hole hubcaps. 4 for your car and 1 for your den! Ends Friday (tomorrow)
http://www.ebay.com/itm/321977471823...84.m1555.l2649
  #73
Old 03-12-2016, 05:31 PM
Default NOS Pitman Arm 63 Tempest
I have one NOS '63 Tempest Pitman arm: this is for a car with standard steering.
Comes in it's original Orange metal end Saginaw cardboard tube.
GM part, Never installed.
Instantly improve your steering, every single car out there could use a new one of these!
Price is $250 includes postage & insurance to any US address.
Name:	63Lemans NOS Pitmann Arm_PYs.jpg
ID:	423467   Click image for larger version
Name:	63Lemans NOS Pitmann Arm_PYs_a.jpg
ID:	423468   Click image for larger version
Name:	63Lemans NOS Pitmann Arm_PYs_b.jpg
Peter Serio
  #74
Old 03-13-2016, 03:25 PM
tom s tom s is offline
Peter,I have a Moog and TRW pitman arm.They are marked K5084.They are marked 63 tempest is that correct?The TRW part is 18603.Tom
  #75
Old 03-13-2016, 04:01 PM
Never mind,they are idler arms.Tom
  #76
Old 03-13-2016, 04:02 PM
Peter,yours looks like a idler also,the pitman has a lot larger hole.Tom
  #77
Old 03-13-2016, 04:33 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default pitman arm hole
Tom, I believe the pitman arm has cerations inside the hole, while the idler arm has threads. The idler arm is cerated to fit on the steering box output shaft without turning. An idler arm has threads so it will turn with the steering link. Looks like Pete has a pitman arm for a manual steering application.
  #78
Old 03-13-2016, 04:38 PM
I just looked at my original 63 car.The arm attached to the steering box has a arm with a lot bigger end where the arm on the pass side is smaller.I have 2 NOS idler arms which are exactly like the one on my tempest.They are splined and not threaded.Tom
  #79
Old 03-13-2016, 04:49 PM
This is my standard steering 63 Pitman Arm. John
Name:	STANDARD PITTMAN ARM.jpg
  #80
Old 03-13-2016, 04:54 PM
That looks like the 3 idler arms I have here?Tom
