Old 07-03-2021, 06:48 AM
DANTIP DANTIP is offline
Default Firm pedal/weak brakes
I drove my ‘67 GTO last night and the car just doesn’t brake well with normal pedal. The car has manual drums all around and the pedal feels right. I own a 66 with manual brakes that stops perfectly with much less pedal effort.
I have driven the car very little since buying it and would like it to stop like the 66!
It kind of acts like the pads aren’t providing the right friction to the drums ( glazed pads, or fluid on the pads)
Or maybe my pedal effort isn’t generating the right pressure at the wheel cylinders??
Old 07-03-2021, 07:31 AM
chrisp chrisp is offline
Pull all 4 wheels & check , i am sure you will find the issue.
Old 07-03-2021, 03:16 PM
geeteeohguy's Avatar
I had this issue with my '65 a year or two ago and it turned out to be a collapsed rubber hose to the rear brakes. I was only getting front brakes. Mine is a manual brake 4 drum car.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 07-04-2021, 10:39 AM
Goatracer1 Goatracer1 is online now
Does the master cylinder look like it was changed before you bought the car? If it has too Large a bore master it will act that way. My 1967 had that problem.
Old 07-05-2021, 09:19 AM
My master cylinder is definitely not original. Believe it is a Raybestos casting number 29863.
I can’t find much info about it???
Old 07-06-2021, 04:42 AM
Geoff Geoff is offline
If the m/c bore is larger [ than it should be ], you will have a harder pedal.
Old 07-06-2021, 09:03 AM
GoGoat GoGoat is offline
i have a 66 with manual drums. I'm on fire dept, had a call and had about 4 stop signs to go thru getting there. Just that one trip glazed the shoes badly. Also replaced shoes with high mileage shoes, they were terrible, went to cheap softer shoes and worked much better. Didn't care about mileage, just wanted brakes. Good luck
Old 07-07-2021, 05:36 AM
Default Brakes
I have a new rear/center hose and correct MC coming. I’ll pull the wheels and take a look at the shoes and drums as well. Hope no wheel cylinder leaks are found!
Old 07-07-2021, 06:31 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
When jacked up, have someone push brake pedal and spin each wheel to make sure cylinders are working.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
