Old 10-11-2020, 04:55 PM
Chiefkey Chiefkey is offline
Default Stabilizer Shaft to Strut Insulator
If anyone has a "stash" of NOS items, I need a Front Stabilizer Shaft Strut Insulator in order to make some copies. It's Group # 7.243, Part # 539354.
If that turns out to be another piece of "unobtainium", a used one that's in very good shape might work. I know... good luck on that ! But you never know.
JK
Old 10-12-2020, 01:09 PM
Radman's Avatar
Radman Radman is offline
I don't have any new ones. But here are pictures of the used one in the barn.
ID:	551304   Click image for larger version
ID:	551305   Click image for larger version
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 10-12-2020, 03:30 PM
We're looking for the ones at the end of the sway bar that wrap over the stabilizer shaft. The rubber bushings on the threaded end are already available.
JK
Old 10-12-2020, 09:22 PM
TransaxleTempest62 TransaxleTempest62 is offline
JK
Isn't that what he showed you in the first picture?
Old 10-12-2020, 11:09 PM
Yep...Just wanted to be clear.
JK
Old 10-14-2020, 02:49 PM
Peter Serio's Avatar
Chiefkey, Do you have a way to 3D print a new rubber part like that? Just wondering, or are you going to make a mold?
Peter Serio
Owner, Precision Pontiac
Old 10-14-2020, 03:49 PM
Pete... We'll have to make a mold. From what I've been told, I doubt we can 3-D print in rubber, but it may be possible to "scan" a used piece, then clean it up digitally and then use that data to 3-D print a hard copy that can then be used to make a mold. Seems like a lot of effort for a little rubber insulator, but I guess why not ! Still be easier if a NOS piece could be found.
JK
