Old 08-24-2020, 10:55 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default wanted ohc fan and pulley set up
looking for complete pulley set up, water pump, crank and fan set up, non ac preferred
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 08-24-2020, 06:56 PM
Jeff Hamlin's Avatar
Question
Is this for the '69 Bird or something other?
Old 08-24-2020, 06:57 PM
sprintbird sprintbird is offline
What year? I assume 1bbl engine? I can help you.
Old 08-24-2020, 07:22 PM
69 1 barrel power steering no ac
1964 540 gto
Old 08-24-2020, 09:24 PM
I have a rebuilt water pump, and a fan. I think I have a double water pump pulley, but not sure about the crank pulley. I will look tomorrow or Wednesday. I have the parts in a storage unit.
Old 08-26-2020, 08:55 PM
I do not have a crank pulley. Wasn’t the pulley integrated into the harmonic balancer? I believe 66 is the only year that had a bolt on pulley. I have the fan, spacer, bolts, and water pump double pulley. I even have a NOS 69 water pump if needed. PM me if interested. Thanks.
Old 08-27-2020, 06:28 AM
Arrow FWIW...
You are correct the '66-'67 1BC Damper utilizes a bolt-on accessory pully.
'68 1BC Damper is a massive one piece;
Thread Tools
Display Modes
