Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-06-2020, 10:15 PM
Donny1973 Donny1973 is offline
Default 1970 400 Complete
I have a '70 400 complete carb to pan, flexplate to fan, that I'm not going to use. I was told it's a good runner but I haven't heard it run so it's being sold as-is. Appears to be all original with the exception of Edelbrock carb and performer intake, and HEI distributor. Has the original #16 heads with August 12 and 13, 1969 date codes. The 9799914 PD block is date coded August 14, 1969. It's very clean under the valve covers and has polylocks on the rockers. I scoped a couple of the cylinders. They're stock bore and the walls look great with no noticeable ridge. I also scoped up into the oil pan and saw that it's factory drilled for four bolt main caps but has the original two bolt caps. It turns over nicely with great compression. It still had oil when I got it and it looked good. I'd prefer local pick up but can load it on a pallet and drop it off at a shipper in the Melbourne Florida area. Buyer must make all arrangements. $1000 if picked up or $1100 if I have to deliver it to a shipper. I have many more photos if anyone's interested.
ID:	550992   Click image for larger version
ID:	550993   Click image for larger version
ID:	550994   Click image for larger version
Old 10-06-2020, 11:45 PM
grandam1979 grandam1979 is offline
Location?
Old 10-07-2020, 01:03 AM
Scott Thelander's Avatar
Old 10-07-2020, 10:59 AM
Old 10-07-2020, 01:08 PM
Bummer to far for me.
Old 10-10-2020, 08:55 PM
Ttt
Old 10-10-2020, 11:49 PM
patox's Avatar
patox patox is offline
Send a message via MSN to patox
email sent.
Let me know if you get it
Old 10-18-2020, 06:09 PM
Sold
