Old 04-27-2021, 12:57 PM
Sterly Sterly is offline
Default 455 main bearings failed
I've stripped down a friend's 455 +.030 and found on main bearing number 2, both halves have completely lost their tension (spread?) and just drop into their housings. The mains are -0.010. All bearings were in a mess because the engine had lost cam lobes in the past and a lifter had come apart so I was expecting messed up bearings but not a pair of loose shells. The other main brgs were fine in that respect. No evidence of overheating as far as I can tell. Also no evidence in the cap or block that either bearing had been moving. What might have caused this?
Mark
Old 04-27-2021, 01:30 PM
steve25 steve25 is online now
That's strange!
Are you sure neither shell was moving because if it was the number and letter impression from the rear of the bearings would look smeared in the cap and in the block .
On the other hand if there is no impression in just that number 2 cap of upper Bore then something was off even when that motor was put together and even fired and it's lucky that the Bearing did not spin.
I would very carefully check that blocks main webbing for cracks and the Crank also!
Old 04-27-2021, 01:39 PM
Thanks for the quick reply. All the imprints of the lettering were readable, cap and block, with no smearing - just the same as the others which is why I didn't think it had been moving. Strange indeed.
Old 04-27-2021, 02:26 PM
Formulajones's Avatar
Sounds like possibly a line bore wasn't done properly, or maybe not at all, and that particular saddle just never had enough crush to start with.
https://youtu.be/XqEydRRRwqE
Old 04-28-2021, 09:43 AM
I think the saddle size must be right or close because shells from one of the other positions snap in just fine. I don't have the block at the moment so I can't do any measuring.
The Following User Says Thank You to Sterly For This Useful Post:
Old 04-28-2021, 12:27 PM
That would be a good thing to know.
I'd check the oil passages around that main, and check the crank around that main area.
Old 04-28-2021, 12:35 PM
Maybe defective Bearings from the get go!
Shiny Shiny is offline
Any chance the assembler filed or ground the shell to try and adjust clearance?
Old 04-28-2021, 12:36 PM
Yes, that's what I was wondering
Old 04-28-2021, 01:12 PM
Can you post a picture of that # 2 main bore ( both cap and block side ) and then 1 or 3?
Old 04-28-2021, 01:41 PM
Unfortunately the block, crank and old bearings are at the machine shop. I don't think the bearings had been filed/ground though.
Old 04-28-2021, 02:04 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Make sure you mag the crank. I had that happen. The bearings lost their crush. They just fell out of the saddles when I took the motor apart to freshen it up. I took it to the machine shop and showed them. They magged the crank and found it to be cracked. The crank was flexing around and beat up the bearings. Thank God it didn't break all the way.
Old 04-28-2021, 02:25 PM
Ah, that makes sense. I told them the problem and they said they would mag the crank anyway but they didn't tell me of their suspicions.
Old 04-28-2021, 04:43 PM
Half-Inch Stud's Avatar
Dreadful mystery for a loose bearing shell. Can you. determine if 1 or both are shy?
Old 04-28-2021, 05:18 PM
One things for sure if nothing else comes up to say that the block is in some way at fault and the crank mags good I would still replace the crank as could be cracked deep inside and that would mean it would pass a mag test and then fully fail and take
Everything with it!
Old 04-28-2021, 09:11 PM
49Diesel's Avatar
49Diesel 49Diesel is offline
I doubt the bore is at fault , but installation of the caps and measure to compare would verify . Check if the numbers are correct for size on the bearings ( .010 " ) , I've seen a wrong bearing put in the box and if not checked the engine would go together thinking all was correct. Even mic that bearing each 1/2 and see if it is correct .
1965 Pont Custom Sport
1957 Pontiac Thatcher Wagon
1957 Pont Sedan Delivery
1958 Pont Sedan Delivery
1958 Impala Sport Coupe
1958 Impala Convertible
1958 Delray Sedan Delivery
....and a few more....
Old 04-28-2021, 09:34 PM
Formulas Formulas is offline
I beat the dog pizz out of my old 400 in my 68 GTO spun a rod bearing from detonation / advanced timing the main bearing shells popped out when I pulled the crank out of it
I put it together 4 years earlier with std TRW forged pistons the bearings were fine going in circa 1982
Old 04-29-2021, 03:57 AM
Thanks for all the replies. The shells definitely had the correct numbering. I will report back when I have some news.
Thread Tools
Display Modes
