Old 02-18-2025, 09:24 PM
AMX guy AMX guy is offline
Default Mystery Brown Wire Coming From Firewall On '66 GTO
I've looked at every wiring diagram I can find and I can't find where the single brown wire coming out of the grommet on the far left side of the firewall goes. it looks factory and has a broken off end on it.
Old 02-18-2025, 09:45 PM
4dblnkldude's Avatar
Blower motor?
Old 02-18-2025, 09:51 PM
OG68 OG68 is online now
Tachometer Lead? Not normally shown on the diagrams
2007 Cadillac SRX
Old 02-18-2025, 10:41 PM
Far left side as in driver side?
I'd go with the tach wire also.
Old 02-18-2025, 11:04 PM
Yes drivers side. the blower motor is already hooked up.
Could be tach, it has factory rally gauge. the length would be about right. I already have 2 wires going to the coil in the harness, but I haven't started the engine yet so I'm not sure if the tach is wired in. it did work before the restoration.
Old 02-19-2025, 02:03 AM
Then it may be missing the fuse section.
2007 Cadillac SRX
Old 02-20-2025, 10:26 PM
bbnotop bbnotop is offline
On my 64, with upgraded disc brakes and an Autowire harness, there is a brown wire in that area that goes down to the brake warning light switch on the proportioning valve.
Old 02-20-2025, 11:17 PM
This is all original so it never had a proportioning valve.
It comes out of an odd looking gromet on the far left drivers' side. it's definitely factor wiring.
I guess when I get it running if the tach doesn't work I could try it there.
Old 02-21-2025, 01:49 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
It's definitely tach wire. See '66 shop manual pic below.
Old 02-21-2025, 11:54 AM
Thank you, it seems like it should be in the harness but it is what it is.
Old 02-21-2025, 12:18 PM
From what I've seen, optional equipment usually had their own harness and I understand the logic behind that. Reduces the cost of additional wire(s) or the number of different harnesses.
2007 Cadillac SRX
Thread Tools
Display Modes
