Z-bar/ clutch pedal repair bushings
Z-bar/ clutch pedal repair bushings these flange bushings repair the wearable egg shaped holes / you will need to weld your male ends & then file fit these to fit . The elongated holes would need to drilled to 3/8" to accept the repair bushing , check both holes on zbar & the clutch pedal hole as well . Welding is only required to fix the male ends on the zbar linkage from the pedal to zbar ends & clutch adjustment rod end . Also makes a nice smooth pedal / non binding . $30.00 for 3 pcs. as per required .
Available.
In stock.
Bump
A few sets left.
Bushings are back in stock.
If the male ends are good then no welding is needed .
Bump
Fits 5/16 [0.3125] ends only set of 3 $30.00 shipped USPS with tracking & delivery confirmation.
