Old 07-02-2020, 04:16 PM
grd777 grd777 is offline
Default need route info for reverse lock out wire
working on my 72 and i am running some of the wiring for the car , not sure how the reverse lock out wire runs . i now how it starts at the switch , but lost after that
Old 07-02-2020, 06:07 PM
also need to know which hole does the tach wiring go thru
Old 07-02-2020, 06:45 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Reverse lockout wire? There is a mechanical linkage that goes from the base of the steering column to the transmission.
Old 07-02-2020, 06:49 PM
sorry i meant the neutral safety switch
Old 07-02-2020, 08:01 PM
marxjunk marxjunk is offline
you need an assy manual...its a great investment, and you would get instant answers to your needs
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-03-2020, 12:33 AM
Formulabruce's Avatar
Your car is an automatic, The neutral safety switch is on the steering column, on the top behind the gauges and support. It is actuated, like the reverse light, with the back drive linkage which goes from the trans, to the frame and up to the column. This wiring is part of the dash harness.
Tach wire goes through a big hole by the fuse box, and has a boot with a nose on it to keep water out.
Grommet has a slice in it, which should face downward. Hole in Grommet is big enough for 10 wires , but thats whats used.
Name:	tach wire hole.jpg
Old 07-03-2020, 10:02 AM
78w72 78w72 is offline
i suggested that quite a while ago for his 80 t/a. no reason not to get a manual when restoring or working on any car, unless you are very familiar with them or took it apart yourself with pics & bagged/labeled parts.
Old 07-04-2020, 06:26 AM
That means I will not be talking to you guys very often that’s not going to be fun
I like the input and photos that the guys here give out, plus the manual sometimes is not very clear on some items , but I guess I better get them
Old 07-04-2020, 10:10 AM
just a suggestion, a manual is usually very clear & explains or shows diagrams for almost everything you ask about or would run into. nothing wrong with posting some questions but forums can give lots of opinions that may not always be accurate or the correct way to do something.
just saying that if youre not familiar with these cars, a manual has all the info you need. even a cheap chiltons paper back one can be a huge help but a GM one is excellent even if just for things like torque specs etc.
Old 07-05-2020, 08:21 AM
Yes I agree it time for to. Buy one
