Old 06-08-2016, 02:08 PM
SD455DJ SD455DJ is offline
correct, all the 69 B cars had only two transmission options, standard equipment was a 3 speed manual sycromesh on the tree and optional was a TH400 automatic three speed on the tree. All engines including the HO were available with either trans with the following two exceptions... the NC option regular fuel 265horse-400 2 bbl and the mid year optional 340horse-400 4bbl were available only with hydramatic.
You could still order buckets (black only) in only Catalina or Bonneville two door models but no console or floor shift of any kind were offered. Note that some early factory literature incorrectly shows a 4 speed option.
Anyone ever see a 3-on-the-tree 400 4-bbl or 428/428 HO B-body? (Rhetorical question, I don't expect to get any responses...)
Dennis
Old 06-08-2016, 02:18 PM
The 3 on the tree wasn't available with the 400 4bbl but I have a 428-360 manual engine, which btw was in effect an HO engine less the long branch manifolds with 62 screw-in big valve heads, 067 cam, 4 bolt mains, windage tray, HO distributor and carb, none of which were on the 428-360 automatics which were basically a 428 with a 4bbl but otherwise built to 400-290 2bbl specs.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 06-08-2016, 04:23 PM
Diego Diego is offline
Another observation is the lack of the M-21 close ratio trans even with the 3.90 gears in the GP.
Sure about that?
Name:	1969 Grand Prix.jpg
Old 06-08-2016, 04:41 PM
blubomber's Avatar
blubomber blubomber is offline
'69 428 HO B body cars had a PC coded TH 400. The std unit for all others was coded PA or PB.
I do not know the exact differences but I think the HO PC units had a stronger sprag, might have had an extra clutch pack, probably had a different governor setting and different valve body shift points.
Std rear end for a 428 HO a/t B body was the 3.42:1. For some reason they listed a 3.23 for m/t cars but since they didn't make any I am not sure how accurate that is although it is probably applicable to GP's.
Dennis/SD455: PM me or better yet call me at 571 265 5950. I am leaving work in about 30 minutes and will be on my phone after that.
'69 Bonneville convertible
Warwick blue/ parchment interior
53 option accessories
2 more to go :-)
Old 06-08-2016, 04:50 PM
blubomber's Avatar
'69 428 HO's used several parts from the GTO bin.
7268 carb
1119 distributor
#62 heads: screw in studs, large valves, springs?
.067 cam
plus long branch manifolds
Did not know there was difference in the windage tray
To the best of my knowledge only 726 B body 428 HO's were built plus another 12xx for GP's for a total of just under 2000. That represents less than 1/2 of 1% of the total B body and G body production that year.
2 more to go :-)
Old 06-08-2016, 04:59 PM
Originally Posted by Diego View Post
Sure about that?
Diego, Now I am (lol). You really can't can't put a lot of faith in the factory printed materials.
Dennis
Old 06-08-2016, 05:01 PM
Blubomber, I'll pm you later, busy with running around right now. Dennis
Old 06-09-2016, 10:05 PM
4214speed 4214speed is offline
Hey Diego you said 135 68 gp 428 how cars were built . Is that stick and auto cars. If so is there any break down of 4 speed cars. Also I have a 68 428ho 4 speed ventura with a 4.11 posi manual steering and brakes what do you think maybe 1 of 20 built like that. Thanks for the info.
Old 06-09-2016, 10:13 PM
The 135 is for all transmissions.
If you give me the body code and option codes you've listed, I may be able to find out something. There's some interesting combinations that are listed that one wouldn't normally expect but generally I probably will only be able to find Catalina HO/stick for you....if the page is not missing from the Archives.
Old 06-12-2016, 10:52 PM
blubomber's Avatar
SD455SJ Nothing heard..
2 more to go :-)
Old 06-15-2016, 11:47 AM
Bump....
Old 06-15-2016, 09:17 PM
Sorry I forgot to get you the information what do you need the Vin code I'll try and take a picture of the Phs too
Old 06-15-2016, 10:23 PM
Oh the PHS would be perfect!
Old 06-21-2016, 07:20 PM
I'd love to see it too.....Dennis
Old 07-01-2016, 12:15 PM
bump
Old 07-08-2016, 04:58 PM
Just got the invoice from 4214speed so when I get the chance, I'll post it and any info I can gather.
Old 07-13-2016, 12:00 PM
Diego, Looking forward to seeing that. Dennis
  #38
Old 07-19-2016, 11:55 PM
Went to Carlisle, so I've been MIA. However, I took the time on the plane to restart compiling information that I started a few years ago.
I'll reply in full when I'm done in a few days, but here's some info (if it hasn't been stated yet):
173 Catalinas had the 428 HO
363 Cats had the M20, out of 2,546 with manual tranny in total (hence, the difference is the 3-speed).
I have some codes I need to translate (body and option) but it's progressing. One of the problems I have is that all the stats are from photos, and some of them are not clear. I want to make sure I don't post incorrect info or misunderstand how things are laid out.
  #39
Old 07-22-2016, 07:22 AM
Diego, Waiting with utmost anticipation to see what you find out.
Dennis
  #40
Old 07-22-2016, 09:07 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Cat
Sounds like the car I purchased from Pa. 68 Cat 2 door sedan 428 HO, close ratio 4 speed, 4:11 special order rear axle ratio, heavy duty battery, heavy duty cooling and fan, shoulder belts, bench seat, poverty caps with 15 inch wheels. Vedoro green with black cloth interior. Numbers matching. KC
