Old 02-06-2017, 08:21 PM
cnc's Avatar
cnc cnc is offline
Default Manga flow x pipe
Anyone here have any input on these x pipes or would u suggest another
I'm wanting to upgrade to 3 inch pipes off the headers to the muffler with an x pipe to replace my 2 1/2 inch x pipe set up
Thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 02-06-2017, 09:32 PM
krisr's Avatar
krisr krisr is offline
I run one. I think I got it from eBay over here. It's a Chinese knock off of a magnaflow from the appearance. Either way it works fine.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 02-06-2017, 09:55 PM
cnc's Avatar
cnc cnc is offline
There on for sale close for $80 it's stainless but my exhaust is not.....not sure how much of an issue that will be
Old 02-06-2017, 10:01 PM
krisr's Avatar
It'll weld fine. If you're worried just put flanges on but I wouldn't bother honestly.
Old 02-08-2017, 02:57 AM
ta man ta man is offline
I have the PYPES 3 inch X crossover on mine it fits well.
Old 02-08-2017, 08:19 AM
cnc's Avatar
cnc cnc is offline
Just wondering how tight it will make the frt system...from the headers to the cross over then to the mufflers as I'm only changing the frt section out...compared to the pypes crossover
Ernie can u snap a pic of your cross over setup so I can see how much diff it is from this....
Old 02-13-2017, 01:44 AM
Before I pull the engine this week I will take a picture.
Old 02-13-2017, 12:01 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
IIRC the X should be 10" past the cross member.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 02-14-2017, 11:23 AM
Formulajones's Avatar
We run 3 different brands of X-pipes. The BBK on my sons car looks like a knock off design of the Magnaflow in question. My father runs a Dr. Gas, and I have a Pypes setup on another.
The Dr. Gas is the only "X" I'm aware of where they designed it for a specific application based on engine size and power made (ie: the size and shape of the crossover inside the "X") Gets a little spendy though.
As far as the other X's go they all pretty much perform and fit about the same. Packaging gets a little tighter so you end up positioning it in the best location for your particular car.
The Pypes fit very well on my 70 Formula, tucked up nicely and cannot be seen anywhere along side the car. Pretty happy with that setup.
Old 02-14-2017, 12:17 PM
cnc's Avatar
cnc cnc is offline
Yes that's why I'm looking for the pypes...
Old 02-16-2017, 04:57 PM
JC455 JC455 is offline
The PYPES is adjustable too- that's my biggest knock on some other brands.
That adjustability will allow it to fit up nicely on the inlet and outlet sides of the X.
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
