Old 10-09-2017, 03:24 PM
napster's Avatar
napster napster is offline
Default 1969 RAIV value ?
Guys, I need some help on the value of a 1969 RA IV that is complete from Carb to oil pan. I don't know the condition of it at this time, but would like to get a feel for the numbers before it is looked at for value.
Please give me your estimate from bad condition to very good.condition.
Thanks,
Jim
Old 10-09-2017, 03:28 PM
ponjohn's Avatar
ponjohn ponjohn is offline
It will always be worth more to someone restoring a car. And even more if the date codes work for a specific car.
My guess would be 3k-10k. Assuming: correct carb, distributor, intake etc.
Old 10-10-2017, 06:26 AM
Please note that for the RA4 heads to be production original the machining for the center head bolt under the valve cover will be seen to have wiped out 80% of the casting date pad.
This would have a huge impact on the worth of the heads if they where purchased over the parts counter!
Old 10-10-2017, 10:00 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Carb is worth $3500. Heads $3000. Intake $750. Block $3500. Figure in the other parts.
As someone mentioned if you find the car that belongs in could bring huge money!
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 10-10-2017, 10:33 AM
RocktimusPryme's Avatar
I would think your more likely to get more money separating it. But people would also call you names for that. I might take less money and keep the whole thing intact. Sleep better at night.
Old 10-10-2017, 01:01 PM
15 to 20k if everything there is correct and complete.
Old 10-10-2017, 01:14 PM
Formulas Formulas is offline
Also condition is everything .. You have to question why was it taken out of service car wreck or spun bearing dropped valve .. I wouldn't pony up serious money for the short block without looking under the oil pan and valve covers while rotating
Old 10-10-2017, 02:19 PM
Any idea of what the engine came out of?
2007 Grand Prix GXP 5.3L
Old 10-11-2019, 01:51 AM
turbo69bird's Avatar
Depends if it's from a gto or a firebird
Makes a big difference price wise.
960 HP @ 11 psi, 9.70 at 146.
Old 10-14-2019, 06:52 PM
nmoreilly nmoreilly is offline
If it's an SR block will also effect value. Would to see if there is a VIN on the block, what the casting date is, date on the carb. A lot of the "original" 7028273 manual carbs are clones. I think the auto carb also brings less money. I agree if it's all original and correct it would be worth strong money to the person with the car it came out of
Old 10-14-2019, 07:10 PM
tom s tom s is online now
Did I miss if its a auto or stick shift engine?A stick shift carb is worth way more than a auto.The code on the block would really help also.Tom
Old 10-14-2019, 07:26 PM
For 69 GTO's
WW is the manual engine code
XP is the automatic engine code
