73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 08-20-2018, 04:14 PM
leeklm's Avatar
leeklm leeklm is offline
Default Carpet install?
Posted this on the interior section, but thought some of you may have had experience...
I found procedures online for cutting the L around seat bracket's, but how about the large pad for rear seat bracket that houses the seat belt retractor?
The rear outside seat bracket on the 73 A-body sits on top of the seat belt retractor, which is mounted to the floor. What is the proper way to cut carpet around this piece?
Thank you!
Sent from my XT1585 using Tapatalk
Old 08-20-2018, 11:26 PM
cdrookie cdrookie is offline
I poked a hole in the carpet where the bolt goes and used a razor blade to cut out a square big enough for the bolt to go through. Might not be the correct way, but it works and you can't see anything when it's all bolted up.
Old 08-21-2018, 09:09 AM
TAKerry TAKerry is offline
I did the same as cdrookie (although my car is a 77).
